12-11-2013 08:38 AM
I have a SG300-28 and would like to configure through CLI not menu. How do I get to Cli from Menu?
I am running Boot version 1.0.0.4 and SW version 1.0.0.27, Do I need to upgrade both boot and SW or Just SW?
12-11-2013 10:03 AM
Hi rod3,
Typically SSH/Telnet is disabled by default on devices. In order to activate it you will need to go through the WEB GUI to Security > TCP/UDP Services and check the boxes that say SSH or Telnet then click apply.
Then using a Terminal program of your choice you can connect to the switch and configure it. Be advised that the CLI is not exactly the same as regular IOS.
-Trent Good
** Please rate useful posts! **
12-11-2013 04:38 PM
CLI was not available on the 1.0.0.27. That was the first production release. If you want the CLI a firmware upgrade is mandatory.
-Tom
Please mark answered for helpful posts
