How to access C2960 switch using Cisco Network Assistant.
techcoora
I can not figure what Username and password to use for "Please enter your username and password for Level 15 access on "192.168.1.253" when I enter 192.168.1.253 in Connect to: and select OK.
The lever 15 username and password that I can use for SSH does not work.
Milos Megis
Level 3
Level 3
try to insert your enable password (enable secret password) with blank username.
This is default authentification of HTTP server.
You can change it with command:
ip http authenticaton ...
Milos Megis
Level 3
Level 3
Yes, that does work in spite of me entering aaa new-model
I found ip http authentication local changed so username and password for Level 15 worked for CNA logon
Is there another way CNA can be accessed?
Is there a way to access using the ip http secure-server?
You can enable ip http secure-server and login to web management with https://ip_address_of_switch
But I never used CNA. I prefer CLI :-)
I have also tested that if you deny telnet connections then you will not able to connect to http server
Let me switch the rest of this discussion to Discussion How to use the WEB BASED DEV MGR?
