How to Assign IP address to VLANs when using a GUI
dumisanid
Hi Guys
I have just purchased a SG300-28P switch I am using a GUI to do my config. I cant create VLANs just fine on this but I can not assign IP address to the VLANs.
I just want to have a Data and Voice VLAN on this I am planning on leaving data on VLAn 1 but I can't seem to find an option to assign an IP address to my voice vlan.
Please can U assist in this.
For some odd reason I cant access this switch using a console port.
Tom Watts
Hello Dumisani,
The switch by default is in layer 2 mode. You cannot assign an IP to any VLAN except the management VLAN.
As for console access, ensure your settings are correctly input;
Baud 115,200
data bit 8
parity none
stopbit 1
flow control none
Additionally, within the GUI, you can navigate to;
Security -> TCP/UDP services and enable the telnet or other features to access the CLI over ethernet connection
Ensure you're on the 1.1.2.0 firmware as well. The 1.0.0.27 software did not have the CLI, everything else above does.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Davidwagman1
Level 7
Level 7
Hi Dumisani,
Your SG300-28P has to be in layer 3 mode. Then, you can assign ip addresses to the vlans under IP configuration -> ipv4 interface.
To go from layer 2 to layer 3, console, telnet, or ssh to the switch and use this command:
Switch# set system mode router
Please note that your existing config will be erased and the switch will reboot.
Then you will notice the web ui menu will look a bit more robust, and you'll have the additional ipv4 address options to set the IP for the 2nd vlan.
What baud rate are you using on the console?  Try these settings?
Edit:   Looks like Tom beat me to it.... nice work
Best,
David
Please rate helpful posts and identify correct answers.
