How to config dhcp snooping for cbs250?
hoa-cv
Please guide me how to enable dhcp snooping on CBS250 i tried the command: ip dhcp snooping but it doesn't work thanks
6 Replies 6
balaji.bandi
check upgrading the firmware and test it. you enter that command not recognized so that not took effective.
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-250-cli/dhcp-snooping-commands.html#wp1279534050
check other thread have same issue :
https://community.cisco.com/t5/switches-small-business/cbs250-24t-4g-dhcp-snooping-support/td-p/4735966
BB
M02@rt37
Hello @hoa-cv
For DHCP Snooping to function on a CBS250, it needs to be enabled both globally and for specific VLANs.
Try also in GUI...CBS250 series switches are designed with a simplified interface to cater to small and medium-sized businesses, and their CLI does not include advanced configuration commands...
Best regards
Can you send me the tutorial file or step by step tutorial link? Thanks a lot.
@hoa-cv
Refer here please:
https://gzhls.at/blob/ldb/7/b/a/d/1a91d8f5204aaaff39026d9ed3a2178cba63.pdf
'DHCP Relay'
Best regards
I need to configure DHCP snooping to set up trust port without setting up DHCP relay
Ok @hoa-cv
so CBS350 could do it, but not the CBS250.
Best regards
