how to copy cisco catalyst 9200 switch IOS into flash
dear all,
I did a factory-reset all on my cisco catalyst 9200 switch.
loaded the ios from TFTP. ( went successful )
but now I want to store the ios in the flash, because when I restart the switch is goes back in the rommon mode instead of loading the ios.
I have used the following command but it didn't help.
#copy tftp://192.168.1.10/cat9k_lite_iosxe.16.10.01.SPA.bin flash
also I cannot login in the web interface with the default username ( cisco or webui ) and password ( serial nr ).
Please help/advise
Jaderson Pessoa
Hello guy,
try as below:
copy tftp:\\192.168.1.10\cat9k_lite_iosxe.16.10.01.SPA.bin system:
Jaderson Pessoa
*** Rate All Helpful Responses ***
Leo Laohoo
The syntax is wrong.
The correct syntax is "copy tftp://192.168.1.10/cat9k_lite_iosxe.16.10.01.SPA.bin flash:"
