HSRP issue
frekandy
i having a lab setup on packet tracer doing HSRP practical. R1 is the primary and R2 is the standby. every thing working fine..
when i shut down r1 interface traffic perfectly routed through r2.
problm is that when r1 interface up. its showing standby.
Andy,
2 Accepted Solutions
Jitendra Kumar
please attach your file or share a snap for your topology that will help to understand the issue...
maybe concerned about the Preemption issue as i suspect if you want to R1 router back as primary.
Jitendra
Jitendra
Jitendra Kumar
hi,
try to give the below command on the R1 on global mode # standby 1 preemt
if your priority default example 100 both side and preemt not enabled. then Primary router will not preemt as master till the other router down.
You need to enable preemt both router.
configure master router priority more then standby
configure a # standby 1 Track interface (outside f0/0 or insidef1/0  )  dcrement -10 0r according to standby router.
need to set decrement number that should less then your standby router so once tracking interface declare as down decrement will happen automatic on your primary router and standby router will preemt it as active till the master came up.
Hope it will help you..
if you issue resolve this statement please mark and resolve. don't forgot for helpful hit..
Jitendra
Jitendra
5 Replies 5
Jitendra Kumar
Jitendra
Jitendra
Snap has been attached.
Andy,
Jitendra Kumar
hi,
Jitendra
Jitendra
balaji.bandi
So you Looking when R1 up that should as active instead of Standby (is this correct)
in that case Do you have preempt configured with priority on R1 so when R1 come online that become Active.
below example give you the config and explanation :
https://community.cisco.com/t5/networking-documents/hsrp-overview-and-basic-configuration/ta-p/3131590
BB
you need to configure preempt option for this auto change. check below guide
https://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/13780-6.html
Good luck
KB
