I can't ping vlan or pc on Switch
majid_peidaei
hellp
i have a problem
I can't ping vlan (192.168.1.1) from pc and inverse
this is my network
now PC0 and PC1 taken ip from dhcp server swithch and OK ,
and I have very simple config
this map is realy and I used packe trace for show you.
1-dhcp
sw(config)#ip dhcp pool ronidhcp
sw(dhcp-config)#network 192.168.1.1 255.255.255.0
sw(dhcp-config)#default-router 192.168.1.2
sw(dhcp-config)#dns-server 4.2.2.4
sw(dhcp-config)#exit
sw(config)#
sw(config)#ip dhcp excluded-address 192.168.1.1 192.168.1.100
2-Vlan
sw(config)#vlan 2
sw(config-vlan)# name soft-sw1
sw(config-vlan)#exit
sw(config)#
3-add ip to vlan
sw(config)#interface vlan 2
sw(config-if)#ip address 192.168.1.1 255.255.255.0
sw(config-if)#no shutdown
sw(config-if)#exit
sw(config)#
4-add interface to Vlan
sw(config)#interface range fastEthernet 0/1-2
sw(config-if-range)#switchport mode access
sw(config-if-range)#describtion Localsystem
sw(config-if-range)# switchport access vlan 2
sw(config-if-range)#no shutdown
sw(config-if-range)#exit
sw(config)#Ctrl+z
sw#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
[OK]
sw#
this is my config
please help
thnkas
Mark Malone
default router should be the vlan ip address as its the gateway for the subnet
change it to below , also each switch should have its default gateway set to in con fog , ip default-gateway x.x.x.x
192.168.1.1
11 Replies 11
Mark Malone
192.168.1.1
ok
in this way
vlan ip 192.168.1.1 and gw ip 192.168.1.1
right?
yes this should be sw(dhcp-config)#default-router 192.168.1.1
this should match the vlan ip address which is already 192.168.1.1
and each switch should also have ...ip default-gateway 192.168.1.1 so traffic can get back to it
ok
now my gateway and vlan is 192.168.1.1
but i can't ping right now
ok is the vlan up/up yes on the switch , you can also ping it locally on the switch itself ?
The pc your pinging from is set for vlan 2 and is also up/up , what its ip address
check the arp table on the switch and its mac table make sure you can see your pc mac address and ip address
this is arp picture
ok cool so it sees one pc correct the .102 address can you ping that you should be able to as its in the table unless something is blocking it software related , are these real pcs or a virtual lab setup ?
i dont have problem with this design in lab
i hav problem in real switch and pc
i have Cisco ME 3400-24TS-A Switch and pc
ye that's what I needed to know because if you have software firewall on the pc it could be set at high strength blocking your icmp traffic on local pc going in / out
make sure your firewall is turned off while your testing on the pcs and av
is the vlan up/up yes and when your on the actual switch you can ping it ok , the oc is on the arp table so you should be able to ping the vlan unless the interface is down
i with this
ronisw(config)#interface range fastEthernet 0/1-7
ronisw(config-if-range)#port-type nni
*Mar 1 06:16:17.803: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, cha
nged state to down
*Mar 1 06:16:48.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, cha
nged state to up
and then i fix problem and i have ping switch with pc
Reply from 192.168.1.1: bytes=32 time=1ms TTL=255
but you are very good help me about dafault route and vlan ip
thanks
ah cool well thanks for posting the fix it may help someone else too
