Inter vlan routing on a Cisco SF 300-24 port switch No internet except when scanning with wireshark
richley1980
I am trying get inter vlan routing to work on a DF 300 - 24 port switch.    I have an existing company network on 192.168.111.0 and want to create a vlan on 192.168.1.1 that can talk to 192.168.111.0.    I have enabled layer 3 routing on the switch via console and also provided the ip routing command. I have the following VLAN's:
VLAN1 - Default 192.168.111.0
VLAN2 - 192.168.1.0
I have enabled DNS and provided my two DNS servers 192.168.111.82 & 192.168.111.212.
I have set the VLAN1 interface to 192.168.111.217 and VLAN2 interface to 192.168.1.1.
Ports FE1 - FE15 are set to access ports and assigned to VLAN1 (untagged)
Ports FE16 - FE24 are set to access ports and assigned to VLAN2 (untagged)
I have set a default route for the switch to 0.0.0.0 0.0.0.0 192.168.111.254 (Draytek 2600 router). I have connected a computer (A) to VLAN1 port FE3 and a computer (B) to VLAN2 port FE16.   I have set Computer A default gateway to 192.168.111.217 and its IP address to 192.168.111.94.    I have set Computer B default gateway to 192.168.1.1 and IP to 192.168.1.2.
Computer A has access to Mdaemon, file server via network drives but no internet (cannot ping google) and can ping computer B and RDP onto computer B.
Computer B can ping computer A and RDP onto computer A but does not have access to the company network i.e MDaemon, file server etc.   It also cannot access the internet.
From the console I can ping www.google.co.uk and all ip addresses in the company network i.e. 192.168.111.82 (DNS server).   I dont understand what i am doing wrong and have been banging my head for days just staretd a new job and desperatly need to get it working so any help would be greatly appreciated
If I scan computer A wirh wireshark the internet starts working wheird!
Configuration show below:
switch7c0a71#show run
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 2
exit
interface vlan 1
ip address 192.168.111.217 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 192.168.111.254
interface vlan 1
no ip address dhcp
exit
bonjour interface range vlan 1
hostname switch7c0a71
no passwords complexity enable
no snmp-server server
interface fastethernet1
switchport mode access
exit
interface fastethernet2
exit
interface fastethernet3
exit
interface fastethernet4
exit
interface fastethernet5
exit
interface fastethernet6
exit
interface fastethernet7
exit
interface fastethernet8
exit
interface fastethernet9
exit
interface fastethernet10
exit
interface fastethernet11
exit
interface fastethernet12
exit
interface fastethernet13
exit
interface fastethernet14
exit
interface fastethernet15
exit
interface fastethernet16
switchport mode general
switchport general allowed vlan add 2 untagged
exit
interface fastethernet17
exit
interface fastethernet18
exit
interface fastethernet19
exit
interface fastethernet20
exit
interface fastethernet21
exit
interface fastethernet22
exit
interface fastethernet23
exit
interface fastethernet24
exit
interface vlan 2
name Development
exit
40 Replies 40
Hi David,
I have added the rules as you described see below:
But it seems to let everything through, if I remove rule rule 41, I have no access to the 192.168.2.0 network at all. Also it seems to be ignoring rule 39 as it should allow me to RDP through to a computer on 192.168.2.0.
I need to allow RDP (3389), SMTP (25), FTP (21), LDAP (389), IMAP (143) between both networks but deny everything else.   The end goal is to deny the SQL server (port 1433) on 2.2. from being able to communicate with the SQL server on 111.0 as the SQL server on 2.2 is a test SQL server.
Hope this makes sense.
Kind Regards
Richard
Hi Richard,
You need to change the mask in rule 40 to 0.0.0.255 if you're using 255.255.255.0 network.
Then add in the remainder of your permit rules, or if its easier, to permit all and just deny the SQL server, your call.
Best,
David
Hi David,
That seems to have worked see ACL below:
Is there a way of blocking traffic from network 192.168.2.0 to 192.168.111.0 as well i.e both ways except for the ports I allow & Deny?  If I try and add a rule to block any traffic from 192.168.2.0 to 192.168.111.0 above or below rule 42 I loose the RDP connection to the computer on 192.168.2.0 from 192.168.111.0 network.  Is it possible to acomplish this.
Kind Regards
Richard
Davidwagman1
Level 7
Level 7
Hi Richard,
43 - Permit Protocol: Any To/From All
42- Deny  Protocol ALL from  192.168.2.0             0.0.0.255 -> to  192.168.111.0       0.0.0.255
41- Deny Protocol ALL from    192.168.111.0    0.0.0.255   ->  to  192.168.2.0     0.0.0.255
40- Permit Protocol RDP   from ALL to ALL
etc
That should block everything, including MSSQL, except for RDP, and the other ports as you've defined above.  Are the other defined services working and just not the RDP?
Richard, please remember to rate helpful posts and identify correct answers.
Best,
David
Hi David,
I have enabled what you have specified above which has blocked traffic both ways but it seems to be ignoring all rules to allow RDP, SMTP, IMAP, FTP ect.  Settings shown below:
Rules 34 - 38 seem to be ignored for some reason not sure why?
Kind Regards
Richard
Hi Richard,
I've attached a screenshot of what it should look like, though its not complete (I didn't do all of the services, but enough so you get the gist). You need both to and from rules and diff source/dest rules:
Best,
David
Hi David,
I would like to connect a server to the Linksys SRW224G4 L2 switch but it needs to be on the VLAN 4 network.
I have created a trunk link between the Linksys SRW224G4 and SF-300 and tagged VLAN 4 on both ends (VLAN1 untagged) and set the server IP to the 192.168.2.* network and given it the default gateway for VLAN 4 192.168.2.249 but it doesnt want to communicate.
I get limited connectivity and no internet access.
The server has bonded nics and is connected to the G3 and G4 ports of the Linksys224G4 and the ports are set to access ports.
I thought I would just have to trunk between the Switches and tag the required VLAN (4)?
Kind Regards
Richard
bhackbarth
A trunk port is only helpful when you have tags identifying which VLAN the traffic is supposed to be on. Your server definitely probably isn't tagging any of its traffic, so any traffic you manage to send back to the SF300 is going to end up in VLAN1 on the SF300's end anyway because you used a trunk port and VLAN1 is untagged. So you'll need to either be on an Access port on the SWR or change the PVID of the trunk to something other than 1, assuming your access ports to your server are not on VLAN1.
If the entire switch is to be a member of VLAN4 from the SF300's side, it makes sense on the SRW side to either use VLAN1 or change the PVID of all the ports to VLAN4. On the SF300 side, depending on whether traffic headed for VLAN4 is tagged or not, the port that goes to the SRW may need to be an access port. If there are tags, then a Trunk port is correct to use.
To summarize: if your access ports to the server are in VLAN4, set your port going  back to the SF300 as access port for VLAN 4.  Then look at the SF300 side and determine whether traffic headed for those aforementioned servers will be tagged as VLAN4 or not (802.11q compatible). If so, you're done. If not, set the port going to the SRW as an access port for VLAN4 so tags aren't needed.
Hi Brayton,
The server is installed on an esxi 5.1 host and is a virtual client (2012 server) so I can assign its interface to a VLAN.   I have set its VLAN port assignment to 4 but I cannot ping anything on VLAN 1 or 4.
Inter vlan routing is working on the SF-300 switch bewteen VLAN 1 and 4 as I have users on VLAN  4 using VLAN 1 resources and they can connect to the domain.
Port G1 on the SF-300 is trunked with VLAN 4 tagged and is connected directly to port E09 of the Linksys switch which is also trunked and tagged with VLAN 4.     The switches are connected direcly via a couple of patch panels.
Because the ESXI Host has servers installed running in VLAN 1 I am unable to remove VLAN 1 from the trunk port and just have VLAN 4.
Do I need to trunk the ports which the server is connected to i.e. G3 & G4 and tag VLAN 4 as they are currently set to access?
Many thanks
Richard
bhackbarth
Hi Richard,
  Definitely set G3 and G4 as Trunk ports if there are multiple VLANs coming in and out those ports. It sounds like there are if the esxi host is advanced enough to allow VLAN configuration. Simply decide what the default VLAN of G3 and G4 is, i.e. the one that will not require any tags at all. Make sure G3 and G4 have that particular VLAN as an untagged member. Then tag the other VLANs that need to flow through. If you had them as Access Ports on VLAN4 before it seems like VLAN4 would be the untagged member.
-Brayton
poojo666
Hi All
I used the "Switch SF300" I want to set the IP Routing. Problem is that I need to put Gatewate to be contagious.
Sample
vlan 1 => IP 192.168.1.1 255.255.255.0.
vlan 2 => IP 192.168.2.1 255.255.255.0.
PC1 (Vlan1)
IP 192.168.1.2  Subnetmast :255.255.255.0 Gatewate 192.168.1.1
PC2 (Vlan2)
IP 192.168.2.2  Subnetmast :255.255.255.0 Gatewate - no gatewate or 192.168.1.254
PC1 ==> Ping to Vlan 2 and PC2  : pass
PC2 ==> Ping to Vlan 1 and PC1  : Verification.
I've tested with the Catalyst 3560 in Packet Tracer 5 do.
http://www.4shared.com/file/MIy7vIJV/FMC.html
