01-18-2016 04:43 PM
Will the c3560-ipservicesk9-mz.150-2.SE9.bin work on the WS-3560G Switch?
We are trying to keep a backup of all the downloaded IOS for our switches, and if we don;t need to download so many files then cataloging will be easy.
Thank you.
Solved! Go to Solution.
01-18-2016 11:57 PM
I would say the answer is yes, as when I go to download software for the 3560G I see this filename.
01-18-2016 11:58 PM
pps. You can check by trying to download the software for the switch. You can do this even if you don't have entitlement (you just wont be able to download the software).
01-18-2016 11:57 PM
01-18-2016 11:58 PM
