09-26-2012 06:39 PM
Good Day. I would like to ask if it is possibe to stack a 3Com 3cr17161-91 to a layer 3 Cisco Switch? The two will be stacked using the avaialble SFP modules.
Solved! Go to Solution.
09-26-2012 06:51 PM
Hi Rey, not with the small business switches. The small business switches stack with their own product line running the same software. Something like SGE2010 will not stack with SG500-48 as example.
-Tom
Please rate helpful posts
09-26-2012 07:11 PM
Hi Rey, I don't know the direct answer, but I know a Cisco 3750 cannot stack with 3550 because the 3750 supports "stackwise" that doesn't interoperate with the 3550's gigstack. I suspect this may be the same answer for 3rd party vendors.
-Tom
09-26-2012 06:51 PM
-Tom
09-26-2012 07:06 PM
Hi Thomas,
Thanks for this very quick reply. If may I add, what about a Catalyst switch to that 3com model? Not unles that 3com model is also treated as a small business then there is no way to pair it.
09-26-2012 07:11 PM
-Tom
09-26-2012 07:14 PM
Hi Thomas,
Yes I guess you are right. Again thank you so much for your help. I highly appreciate it.
