Is it possible to stack a 3Com 3cr17161-91 with another layer 3 Cisco switch?
reycapoy
   Good Day.  I would like to ask if it is possibe to stack a 3Com 3cr17161-91 to a layer 3 Cisco Switch? The two will be stacked using the avaialble SFP modules.
2 Accepted Solutions
Tom Watts
Hi Rey, not with the small business switches. The small business switches stack with their own product line running the same software. Something like SGE2010 will not stack with SG500-48 as example.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Rey, I don't know the direct answer, but I know a Cisco 3750 cannot stack with 3550 because the 3750 supports "stackwise" that doesn't interoperate with the 3550's gigstack. I suspect this may be the same answer for 3rd party vendors.
-Tom
Tom Watts
-Tom
Hi Thomas,
    Thanks for this very quick reply.  If may I add,  what about a Catalyst switch to that 3com model? Not unles that 3com model is also treated as a small business then there is no way to pair it.
-Tom
Hi Thomas,
     Yes I guess you are right.  Again thank you  so much for your help.  I highly appreciate it.
