Issue with Serial Port and Error Code on Switch Reset.
SteveI
Hello, I've been having some issues with our Cisco Business 350 Switch.
I had recently come back from a travel trip and went to connect to the switch CLI via a serial connection with Putty and the connection didn't work. I tried every baud rate starting from 115200 all the way back to 1200 and that didn't work. The switch needed to be fully powered down to get the port working again. This is the second time this switch has done this and didn't know if it was something that I had in the configuration that would be causing this issue or if it was hardware related.
Secondly, I've got the error below as well every time I remove an ACL from a VLAN. Assigning it initially is fine, but every time I remove the ACL the switch bricks.
00--2000 00:00:00 %SYSLOG-F-OSFATAL: caught segmentation fault exception at addr ess (nil)
signal-num = 11 (SIGSEGV)
signal-code = 1 (SEGV_MAPERR)
reg[00] = 0x896d901c
reg[01] = 0x0
reg[02] = 0x6b
reg[03] = 0x4
reg[04] = 0x896d9288
reg[05] = 0x0
reg[06] = 0x1
reg[07] = 0x2
reg[08] = 0x80000000
reg[09] = 0x1
reg[10] = 0x36af3d4
FP = 0x3734e28
IP = 0x896d901c
SP = 0x896d8ff0
LR = 0x109e278
PC = 0xb6c84228
CPSR = 0x90000010
Fault Address = 0x0
Trap no = 0xe
Err Code = 0x15
Old Mask = 0x0
***** FATAL ERROR *****
Reporting Task: POLI.
Software Version: 3.0.0.69 (date Aug 27 2020 time 15:52:08)
base_address=0x00404000
ros(+0x7c2760)[0xbc6760]
ros(HOSTG_fatal_error+0x14)[0xbc97cc]
ros(OSSYSG_fatal_error+0x258)[0x11b2cfc]
ros(+0x7bd040)[0xbc1040]
/lib/libc.so.6(__default_rt_sa_restorer+0x0)[0xb6c32ec0]
***** END OF FATAL ERROR *****
reg[01] = 0x0
reg[02] = 0x6b
reg[03] = 0x4
reg[05] = 0x0
reg[06] = 0x1
reg[07] = 0x2
reg[09] = 0x1
reg[10] = 0x36d03d4
FP = 0x3755e28
IP = 0x896d901c
SP = 0x896d8ff0
LR = 0x10bf278
PC = 0xb6cca228
CPSR = 0x90000010
Fault Address = 0x0
Trap no = 0xe
Err Code = 0x15
Old Mask = 0x0
base_address=0x00425000
ros(+0x7c2760)[0xbe7760]
ros(HOSTG_fatal_error+0x14)[0xbea7cc]
ros(OSSYSG_fatal_error+0x258)[0x11d3cfc]
ros(+0x7bd040)[0xbe2040]
/lib/libc.so.6(__default_rt_sa_restorer+0x0)[0xb6c78ec0]
00--2000 00:00:00 %SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil)
reg[01] = 0x0
reg[02] = 0x6b
reg[03] = 0x4
reg[05] = 0x0
reg[06] = 0x1
reg[07] = 0x2
reg[09] = 0x1
reg[10] = 0x36ce3d4
FP = 0x3753e28
IP = 0x896d901c
SP = 0x896d8ff0
LR = 0x10bd278
PC = 0xb6ce6228
CPSR = 0x900d0010
Fault Address = 0x0
Trap no = 0xe
Err Code = 0x15
Old Mask = 0x0
base_address=0x00423000
ros(+0x7c2760)[0xbe5760]
ros(HOSTG_fatal_error+0x14)[0xbe87cc]
ros(OSSYSG_fatal_error+0x258)[0x11d1cfc]
ros(+0x7bd040)[0xbe0040]
/lib/libc.so.6(__default_rt_sa_restorer+0x0)[0xb6c94ec0]
reg[01] = 0x0
reg[02] = 0x6b
reg[03] = 0x4
reg[05] = 0x0
reg[06] = 0x1
reg[07] = 0x2
reg[09] = 0x1
reg[10] = 0x37773d4
FP = 0x37fce28
IP = 0x896d901c
SP = 0x896d8ff0
LR = 0x1166278
PC = 0xb6cd8228
CPSR = 0x900d0010
Fault Address = 0x0
Trap no = 0xe
Err Code = 0x15
Old Mask = 0x0
base_address=0x004cc000
ros(+0x7c2760)[0xc8e760]
ros(HOSTG_fatal_error+0x14)[0xc917cc]
ros(OSSYSG_fatal_error+0x258)[0x127acfc]
ros(+0x7bd040)[0xc89040]
/lib/libc.so.6(__default_rt_sa_restorer+0x0)[0xb6c86ec0]
Has anyone experienced this error before? If so, is there a fix with the configuration or does this switch have some hardware issue?
Mark Elsen
 - Upgrade to latest firmware available , if the problem continues then : https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
Try reset with Factory reset button, still same issue - contact TAC case for RMA.
BB
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
