Issues DHCP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-08-2022 01:54 PM
I am running a SG350-10MP switch. I have noted that sometimes there are issues with my DHCP/IPv4 Address assignment. I can see in my logs that error:
%DHCP-F-HASH: Failed insert to DHCPP_alloc_hash_id hash table in function DHCPP_add_addr_from_dynam ***** FATAL ERROR ***** Reporting Task: DHCP. Software Version: 2.5.8.15 [...]
Using G. I was able to find that link: DHCP error
However, I am also running the most up-2-date firmware. This issue occurs multiple times a week, sometimes twice a day.
Does anybody have an idea how I can troubleshoot this issue? Or is it really a known bug as implied here?
Christian
- Labels:
Small Business Switches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-08-2022 02:32 PM
Try rebooting the device and see if that fixes the issue, or contact SMB tac.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-13-2022 04:10 AM - edited 07-13-2022 04:19 AM
Yes, it Seems a bug
you have to create a Tac ticket if the new release version is also affected.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvb96072
Jitendra
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-13-2022 11:01 AM
Thanks for your responses! I am in contact with TAC.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-19-2022 02:36 AM
Have your issue got resolved by the Tac ?
Jitendra
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-19-2022 08:52 AM
thanks for following up. We are still in contact, I hope that we can
resolve the issue.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-10-2023 11:07 AM
I was unlucky to run into this problem, too, and on two CBS350 switches with the latest firmware. Both switches had their DHCP server set up and running fine for long time. One of them was acting as a routing switch. The problem occurred when I was converting my network to use another routing switch. I believe some DHCP table gets corrupted when SVIs are modified. That must be a firmware bug. One switch was rebooting itself in a loop and I had to reset it to the factory defaults. It went a little better with the second switch since I was able to disable its DHCP server and remove the DHCP configuration.
This seems to be a very old issue.
