Login Password Retry Lockout
Soffit
Is there any way to set a password retry lockout limit in Cisco switches CBS-350 and SG-300?
marce1000
                  - FYI : https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-/aaa_commands.html#wp2300931040
 M.
@marce1000  Thanks for your reply.  I have gone through the link that you shared and if I set a login block as mentioned in the document, it will block login attempts from all the users.
I want to set this for individual users, if user1 fails to login 3 times simultaneously then user1 will not be able to login for the next 180 seconds. Is there any way to configure the login block like this?
