03-07-2012 03:31 AM
We're testing the reference system shown in the figure below.
System Description
2960 Configuration details
Four our test puprose, we're using 100Mbit/s ports (22 and 23) as trunk.
In order to obtain minimum jitter We performed these configurations:
Question
With these settings we aim at forcing our synchronization packtes to precede other kind of traffic and go from Equipment 1 to Equipment 2 with minimum jitter.
Unfortunately we experienced high jitter when both synchronization packets and other traffic are sent through the systems.
What is wrong in our assumptions or configurations?
What is the real behaviour of the expedit queue?
03-07-2012 10:00 AM
Seems the right config.
This is the my configuration and it works well:
#global level
mls qos srr-queue input priority-queue 2 bandwidth 20
mls qos srr-queue input cos-map queue 1 threshold 3 0 1 2 3 4
mls qos srr-queue input cos-map queue 2 threshold 3 5 6 7
mls qos srr-queue output cos-map queue 1 threshold 3 5 6 7
mls qos srr-queue output cos-map queue 2 threshold 3 4
mls qos srr-queue output cos-map queue 3 threshold 3 2 3
mls qos srr-queue output cos-map queue 4 threshold 3 0 1
mls qos
#port level
mls qos trust dscp
priority-queue out
What is your IOS version?
Can you use the 2960 Gigabit port?
Regards.
03-08-2012 05:27 AM
Ciao, Daniele
Thank You for your answer.
Our Version is 12.2.
We use 100 Mbit/s ports because for our test purpose we need to saturate a link and we don't have a Gigabit capable traffic generator.
But what is different with a Gigabit port? We think that, since expedite queue is enabled, our synchronization packets should be preferred both in the case of a 100Mbit/s and in the case of a Gigabit port.
Bye,
Massimo
03-08-2012 09:37 AM
At this link you can find a full guide about QoS:
The 2960 supports also the 15.x latest IOS.
Regards.
03-09-2012 04:49 AM
Thank You, Daniele
That's the guide we used to create the configuration described in my first message.
But our tests seem to reveal a behaviour of the expedite queue from the one described in the guide.
We will install IOS 15 and repeat the tests.
Massimo
03-14-2012 06:28 AM
We tested also the new IOS and nothing is different.
In our opinion, priority queue out command ensure us all the bandwith we require but it seems to not guarantee us minimum jitter.
Massimo
03-18-2012 05:52 AM
I am reading on the web because I want to achieve nearly the same as you, Massimo. I am confused about the following: is it expedite queue (priority-queue) the output queue 4 instead of 1? You are sending your Synchronization packets to queue 1, but maybe you have to send them to queue 4?
03-19-2012 01:13 AM
Hi, Agustin
I'm pretty sure the priority queue is queue #1.
I verify this condition by applying a shaping on queue#1, inserting a traffic load exceeding shaping limit and then enabling priority queue.
In this situation shaping is ignored and all the traffic sent through queue #1 is allowed to flow.
In any case I tried also to send packet through queue#4.
Thank You,
Massimo
04-13-2012 01:09 PM
Hi Massimo, did you get some news?
04-27-2012 03:22 AM
Hi, Agustin
No other news about Cisco configuration.
I believe that the issue we found is just a limit and cannot be overcome.
I think expedite queue can guarantee the bandwith but not the minimum delay.
Sorry for the delay in my answer.
Massimo.
