Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2241 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 3708 Views
  • 1 replies
  • 16 Helpful votes
I installed my first SG350 into my network today. As I was driving away from the location the 350 was installed in, I started getting flooded with alerts. It seems, once I got to the location most affected, that the 300 VLAN port assignments were cha...
Hello,   I have created a QinQ VLAN for client. The client is trying to start macsec, but it does not work.  The transmission works, the problem only with running macsec.   Could this be a problem in my switches?   On SF302-08 and SF300-24PP switches...
Nolaan by Beginner
  • 827 Views
  • 0 replies
I have an SG500 small bussines switch. Ports where phones are configured as follows: LAN-PUEBLA-CEDA#sh run int GigabitEthernet 1/1/9interface gigabitethernet1/1/9 storm-control broadcast enable storm-control broadcast level 10 storm-control include-...
dllamas by Beginner
  • 633 Views
  • 1 replies
Hi i just got a SG300-10, and i tried updating the firmware and the bootloader.now im stuck with this:SW version    1.3.7.18 ( date  12-Jan-2014 time  18:02:59 )Boot version    1.1.0.6 ( date  11-May-2011 time  18:31:00 )HW version    V02i tried to u...
I have a number of SG300 switches ranging from -10 to -52 with quite a few -20s. The hardware versions vary.\ What can be said about using configuration files between hardware versions? With the same firmware? With different firmware? I see that the ...
fmarshall by Beginner
  • 744 Views
  • 1 replies
1. What format should a certificate and private key combo have when importing it for SSL-usage? 2. How do you actually import it - either via CLI or the web interface.   I'm trying to import a self-signed SSL certificate into the SG300-28 to secure t...
chgu00001 by Beginner
  • 10056 Views
  • 7 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
