Problem configuring default route
I have an SG300-20 configured with 4 vlans, 1, 10, 20, 30. It is configured for L3.  I use this for my home lab network.  VLAN 1 is connected to my cable modem, and gets it's IP address and gateway via DHCP.  I have a host on VLAN 10, and a host on VLAN 20.  I can ping from one host to the other host just fine.  I can ping from the switch to the hosts, and from the switch to the cable modem and internet.  I cannot ping from either of the hosts to the cable modem or internet.
Here is the relevant switch config (IPs masked):
#sh ip int
    IP Address         I/F       Type     Directed   Precedence   Status
                                          Broadcast
76.xxx.xxx.xx/20    vlan 1    DHCP        disable    No         Valid
192.168.10.1/24     vlan 10   Static      disable    No         Valid
192.168.20.1/24     vlan 20   Static      disable    No         Valid
192.168.30.1/24     vlan 30   Static      disable    No         Valid
#sh ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S   0.0.0.0/0 [1/2] via 76.xxx.xx.x, 21:43:15, vlan 1
C   76.xxx.xx.0/20 is directly connected, vlan 1
C   192.168.10.0/24 is directly connected, vlan 10
C   192.168.20.0/24 is directly connected, vlan 20
C   192.168.30.0/24 is directly connected, vlan 30
It would appear that the switch is routing between all VLANs except VLAN 1.   Any ideas what I am missing here?
Tom Watts
Hi Brandon, I think the problem is you're expecting NAT to work. It feels like to me VLAN 1 has the internet connection and you're trying to put the other 3 VLANs on the internet.
In theory you're right on but without NAT this cannot work. The switch also does not support NAT.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Yep you are absolutely right and now I feel like an idiot.  The source IP never gets changed, and the gateway device has no route back.  I knew it was going to be something simple I had overlooked.  Time to go set up a VM to do the NAT.
Brandon
