04-23-2013 02:06 AM
Hi!
My second problem with sg200-08 (firmware: SG200-08x_FW_1.0.6.2.stk) is when I try to add specific MAC address as secure:
MAC Address Tables - Static Addresses - Add; insert vlan id, port, mac address and select "Secure":
I get error message: "Error: Failed to Add 'Static Address' entry.
Again, thanks for reply!
Best regards,
Boris Bahes.
04-23-2013 06:31 PM
Hi Boris, do you have port security enabled for the port? Secure is used in conjunction with port security.
-Tom
Please mark answered for helpful posts
04-23-2013 09:51 PM
Yes, port security is enabled.
PS. I have downgraded firmware to 1.0.5.1 and problem is still there.
04-24-2013 11:00 PM
Problem solved with second upgrade to new firmware SG200-08x_FW_1.0.6.2.stk this time using TFTP.
11-19-2013 12:34 AM
I have the same problem using the current firmware 1.0.6.2. But even an upgrade by TFTP followed by a factory reset does not help. A downgrade to firmware 1.0.5.1 also does not fix this issue.
Are there any other suggestions?
11-19-2013 02:44 AM
Could try the newest firmware and boot release 1.3.5.58.
11-19-2013 02:49 AM
1.3.5.58 for SG200-08? There is only the firmware 1.0.6.2 on the official download page.
11-19-2013 03:01 AM
Strange as it may sound, try playing with compatibility mode in Internet Explorer. I have found that these switches interface respond well only in IE.
11-19-2013 03:31 AM
Release Notes for 200, 300, 500, and ESW2 Series Switches Software Version 1.3.5.x.
11-19-2013 03:38 AM
The release notes show that the firmware 1.3.5.58 is not compatible with the model SG200-08.
If I try to configure the static MAC adresses with Internet Explorer 9 onwards with or without the compatibility mode it throws a Javascript error in a firmware script file (xui_model_window.js).
