07-29-2011 10:22 AM
These protocols are supported by switches of the 300 series and 500 series?
Solved! Go to Solution.
08-01-2011 04:12 AM
Dear Alejandro,
If you mean weather the switch can pass through these protocols the answer is a definite yes. If you meant something else can you please describe what you meant?
For example TCP is supported in a manner that it can filter trafic based on TCP port (Layer 3+ functionality), so can it do for UDP. Multicast is also handled via IGMP support. Regarding RTCP and RTSP how / for what would you use it?
Thanks and regards,
Zsolt
08-01-2011 04:12 AM
Dear Alejandro,
Thanks and regards,
Zsolt
08-04-2011 08:32 AM
The application for these switches is to manage IP Megapixel cameras
