Hi Guys,
We are migrating our 4507 (IOS 12.2) to 6807 (IOS 15.5SY). We notice the qos command is different.
below is the existing command in 4507.
qos map cos 5 to dscp 46
qos
interface GigabitEthernet3/1
switchport mode trunk
qos trust dscp
We configure the qos trust dscp on the interface.
In the new switch 6807, we are unable to configure the "qos map cos 5 to dscp 46" & "qos trust dscp" on the interface.
I'm going through the release note on the 15.5SY qos part but confused over the command.
To Map cos to dscp, i will insert " table-map cos-discard-class-map 0 1 2 3 4 5 6 7 " This is to map received CoS to internal DSCP map. But how do we convert the cos 5 to dscp 46 ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-5SY/config_guide/sup6T/15_5_sy_swcg_6T/qos_global_and_if.html#40967
Please advise.
Thank you in advance.
Eric
