Regarding SGE2000 Transceivers
bryanlin84
                   please advise can MGBSX1 transceivers use on SGE2000? what type of transceivers can be use on SGE2000.
Rgd
bryanb
Tom Watts
I don't have a compatibility matrix for the SGE, however, the MGBSX1 is compatible. The MGBLX1 and MGBT1 also works. I have used those 3 in my lab.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
according to: https://supportforums.cisco.com/discussion/10932321/gbic-module-sge2000 and manual: https://supportforums.cisco.com/sites/default/files/legacy/2/0/4/68402-Linksys-SGE2000-Manual.pdf
"Use the Linksys MGBT1, MGBSX1, or MGBLH1 mini-GBIC modules
with the Switch. The MGBSX1 and the MGBLH1 require fiber cabling
with LC connectors, while the MGBT1 requires a Category 5e Ethernet
cable with an RJ-45 connector."
Also I'm using two SGE2000 with all SFP ports with MGBSX1 modules (multimode) - without any problems.
danielrenteria
I found this document which validate that Tom said.
http://www.cisco.com/c/dam/en/us/td/docs/interfaces_modules/csbna/mgb/quick_start/guide/Optical_Module_QSG_en-US.pdf
Best regards,
danielrenteria
