03-03-2015 05:03 PM
i am trying to write a script to automate the backup of the startup or running configs to a tftp server, but keep running into issues with the snmpset command. it does not seem to like the STRING TYPE i am setting. at first it complains about the "a" or IpAddress TYPE, so i remove those lines. then it complains about the "i" or INTEGER TYPE. any ideas what i am doing wrong?
#!/bin/bash host=$1 string='snmpWriteString' filename=$host\_$(date +%b.%d.%Y)_startup_config.txt mib=/usr/share/snmp/mibs/CISCOSBcopy.mib rlCopyRowStatus=4 #create and go rlCopySourceLocation=1 #local rlCopySourceIpAddress=0.0.0.0 rlCopySourceUnitNumber=1 #unit number in stack rlCopySourceFileName="" #blank rlCopySourceFileType=3 #startup config, 2 for running config rlCopyDestinationLocation=3 #tftp rlCopyDestinationIpAddress=192.168.88.1 #tftp server ip rlCopyDestinationUnitNumber=1 #unit number in stack rlCopyDestinationFileName="$filename" snmpset -v2c -c $string -m /usr/share/snmp/mibs/CISCOSBcopy.mib $host \ rlCopyRowStatus.0 i $rlCopyRowStatus \ rlCopySourceLocation.0 i $rlCopySourceLocation \ rlCopySourceIpAddress.0 a $rlCopySourceIpAddress \ rlCopySourceUnitNumber.0 i $rlCopySourceUnitNumber \ rlCopySourceFileName.0 s $rlCopySourceFileName \ rlCopySourceFileType.0 i $rlCopySourceFileType \ rlCopyDestinationLocation.0 i $rlCopyDestinationLocation \ rlCopyDestinationIpAddress.0 a $rlCopyDestinationIpAddress \ rlCopyDestinationUnitNumber.0 i $rlCopyDestinationUnitNumber \ rlCopyDestinationFileName.0 s $rlCopyDestinationFileName
03-04-2015 02:08 AM
Hello
place row
at the end of whole command, i.e.:
snmpset -v2c -c $string -m /usr/share/snmp/mibs/CISCOSBcopy.mib $host \ rlCopySourceLocation.0 i $rlCopySourceLocation \ rlCopySourceIpAddress.0 a $rlCopySourceIpAddress \ rlCopySourceUnitNumber.0 i $rlCopySourceUnitNumber \ rlCopySourceFileName.0 s $rlCopySourceFileName \ rlCopySourceFileType.0 i $rlCopySourceFileType \ rlCopyDestinationLocation.0 i $rlCopyDestinationLocation \ rlCopyDestinationIpAddress.0 a $rlCopyDestinationIpAddress \ rlCopyDestinationUnitNumber.0 i $rlCopyDestinationUnitNumber \ rlCopyDestinationFileName.0 s $rlCopyDestinationFileName \ rlCopyRowStatus.0 i $rlCopyRowStatus
My understanding of error "Reason: wrongValue (The set value is illegal or unsupported in some way)" using original command is that value "rlCopyRowStatus.0" could be filled with "4" only in case that all other fields are filled accordingly. For me filling "rlCopyRowStatus.0" with "4" is the GO decision to perform copy operation immediatelly after filling. In original case it not work because you fill this value without filling rest of other related values before.
03-04-2015 01:54 PM
by setting the "-DALL" parameter on the snmpset commnad, i could see that the
line was throwing off things. because the $rlCopySourceFileName variable was blank, the next OID, rlCopySourceFileType.0, was being used as the value. from there the ordinal positioning of all items was off and that is what caused the issue.
the relevant command is now:
snmpset -v2c -c $string -m +/usr/share/snmp/mibs/CISCOSBcopy.mib $host \ rlCopyRowStatus.0 i $rlCopyRowStatus \ rlCopySourceLocation.0 i $rlCopySourceLocation \ rlCopySourceIpAddress.0 a $rlCopySourceIpAddress \ rlCopySourceUnitNumber.0 i $rlCopySourceUnitNumber \ rlCopySourceFileType.0 i $rlCopySourceFileType \ rlCopyDestinationLocation.0 i $rlCopyDestinationLocation \ rlCopyDestinationIpAddress.0 a $rlCopyDestinationIpAddress \ rlCopyDestinationUnitNumber.0 i $rlCopyDestinationUnitNumber \ rlCopyDestinationFileName.0 s $rlCopyDestinationFileName
the issue i now have is getting my tftp server to allow new files to be created. right now the access controls and configs only allow me to write to files that already exist. but that is not a topic for this board.
