SD205 Power Transformer
henie
Hi Team,
Is the power transformer included in the power adatper on SD205 ? Or it is inline within the switch ?
What is the dimension for the power transformer ?
Henry
henie
Would anyone be able to help please ?
When you ask for the 'power transformer' are you referring to the power adapter? Here is a link that describes the contents of the packages and some dimensions.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10007/ps10009/data_sheet_c78-501967.pdf
The power adapter quite small and simply plugs into the wall.  A thin cord then plugs into the SD205.
HTH,
Andrew Lissitz
Hi Andrew,
Thanks for your information. The customer is looking for the specific dimension of the power adapter. Is there any information available on that ?
Henry
