We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
350
(7) -
350X
(4) -
550X
(2) -
Branch Router
(3) -
Buying Recommendation
(8) -
Catalyst Switch
(1) -
CBS Switch
(1) -
CBS110
(1) -
CBS220
(3) -
cbs250
(6) -
CBS350
(22) -
Cisco Bugs
(2) -
Cisco Business Dashboard
(1) -
Cisco Cafe
(1) -
Cisco Software
(1) -
Community Feedback Forum
(2) -
Community Ideas
(5) -
Configuration
(1) -
CSC Content with No Valid Community to Post
(1) -
Device Admin
(1) -
Intent Based Networking
(1) -
LAN Switching
(72) -
Network Management
(30) -
Other Network
(1) -
Other Networking
(2) -
Other Routing
(3) -
Other SD-WAN
(1) -
Other Security Topics
(1) -
Other Switches
(55) -
Other Switching
(21) -
Physical Security
(1) -
Routing Protocols
(1) -
Small Business Network and Smart Storage
(1) -
Small Business Routers
(1) -
Small Business Support
(3) -
Small Business Support Service
(1) -
Small Business Switches
(6,761) -
SmartTV
(1) -
switch
(2) -
WAN
(1)
- « Previous « Previous
- Next » Next »
(Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Catalyst 1200 & 1300 Hardware Install...
Hi,I have an ESW 520 switch, and one of the reasons I bought this switch is so that I could have some piece of mind about what computers are plugged into the wired network.I was hoping to be able to manage this on the ESW 520, however configuring the...
I have recently had access to an SGE2010P and can not find a CLI for it. I have searched on the Internet for instructions on how to get there but they just say to select edit in the login screen but there is no edit when I go to the login screen. Can...
I have a Linksys SRW2024 Gigabit switch with Webview. I need to configure two VLANs on it with one port having access to both VLANs. For example, the default VLAN will have all ports except port 3 and the second VLAN with ports 3, 4, 5 & 6. Could you...
Hi, all my SRW224G4 switches stop sending snmp traps afer some time. When this problem appears all SNMP information becomes inaccessible from web view (communities lits appears empty, views screen starts looping). The only way to sove this is rebooti...
I currently have (2) EF3124 uplinked via fiber. Should there be any issues with compatibility if I install a SRW248G4 switch to replace one of the EF3124 switches over fiber? I realize that the SRW248G4 needs its own fiber module but should there be ...
I am trying to deploy backup solutions for all of our switches and servers and need to know what the power consumption and requirements are for WAT and Volt/Amps. Can anyone tell me what these would be?Thank you,
Hi Team,Is the power transformer included in the power adatper on SD205 ? Or it is inline within the switch ?What is the dimension for the power transformer ?Thanks,Henry
Just bought an SLM2048 and have been trying to get link aggregation with LACP working so that I can get some VMWare ESXi nodes a fatter network pipe.If I do NOT enable LACP while making the LAG (using default STATIC mode), the LAG looks good (link st...
Hi,I have a SRW2048 connected back to a Cisco 6509 core switch. For some reason, I cannot establish a gigabit connection with our computers. Both Lenovo laptops and Dell desktops are failing; they always end up falling back and negotiating at 100/f...
Hi,I have a Linksys SRW224G4 with me. I have successfuly connected the switch with console.When i reboot the switch, it shows me something like this.------ Performing the Power-On Self Test (POST) ------UART Channel Loopback Test .......................
Hello, I have searched the forums but I have not found anything specific to what I am looking for.I am trying to figure out how to query an SRW switch for the full RFC1493 table. If I walk the 1.3.6.1.2.1.17.4.3.1 table, the only MAC addresses and p...
Resolved! problem with ports of two SLM2048
Hello:I have a problem with two models of SLM2048.I only than configured in these devices was 4 Vlans and one link Aggregation port between these devices.I'm detecting than some ports don´t work (I connect one workstation in these port and the port ...
After unplugging, moving, then plugging back in my SLM2048 switch the system light flashes nonstop. The switch was working perfectly before it was unplugged. I have tried holding in the reset button for 10 seconds which causes all the ports to ligh...
I bought this switch in 2006. The Hardware Version is 00.03.10. Software: 1.0.0.50.I will be soon attaching a new Server 2008 to it with HP NIC's and Network Adapter Teaming Software.I know the HP teaming software automatically will use LACP (802.3ad...
We have a SFE2000 switch and we're having trouble configuring IGMP snooping. It is enabled but we are still seeing multicast traffic on ports which have definitely not done an IGMP join - indicating something is not right. The literature on the swi...
