04-04-2012 11:02 AM
Well, I've been learning the eccentricities of Cisco's product lines the hard way! Here's my situation:
I've taken over for an office that has a hosted Cisco IP phone system using a variety of what seem to be older Cisco phones (the one at my desk is a 7960) these are normally powered by the PoE that gets delivered by some Cisco Catalyst 3750X switches. Our office has grown to the point where we've had to place a few people into some semi-jury rigged seats in areas with limited network drops. As a result I need to do something creative to get phones over there.
I first went out and purchased a small 8 port switch with 4 PoE ports on it from a competitor and this was where I discovered that the models of Cisco phones I had needed something generally referred to as Cisco Pre-Standard PoE (or some variation on that theme). I returned the switch and after doing some research decided to buy a Cisco SD208P switch, which a few messages out on the Interwebs led me to believe should be able to power the switch (possibly a firmware upgrade would be needed).
So I got the switch today, and plugged my phone into it and... nothing. No signs of life on the phone. (And nothing as simple as plugging it into one of the non-PoE ports on the switch). I went online to try and find a firmware update, and couldn't find anything. It's also an unmanaged switch, so I'm not even sure how I'd update firmware on it if I wanted to (and there's nothing in the manual).
I went back and double-checked some of the sources that may have led me to believe that this would work and I found what turned out to mostly be people recommending this as a possible option, but not strictly saying it worked for them. I found one person saying it worked for some Cisco phones, but he didn't specifically say they were prestandard ones. Lastly, there is mention of 200 and 300 series switches being firmware upgradable to support prestandard PoE, but from looking around Cisco's site I'm not 100% sure that this switch is actually part of the 200 series despite the number in the name. It seems to show up in a Small Business Unmanaged Switch category online rather than in any proper series.
So, the question is - have I just missed something somewhere? Is there any hope for me? Or do I have to send this back and go for something else? If so, what's recommended? Perferably something in that price range or we might just give in and... gasp... buy power supplies.
Chris.
04-04-2012 01:22 PM
Hi Chris,
The SD208P is an unmanaged switch that does not have any web interface and you will not be able to upgrade firmwares on this switch. The unmanaged switch that you have gotten will only support 802.3af POE standard and does not support the Cisco pre-standard. Also, you did mention the 200 and 300 series switches which are managed switches and with the latest firmware of 1.1.2.0, you will be able to power up your 7960 phones. The models are called SF200, SF300, SG200, and SG300. Please make sure to get the models with the letter "P" for POE. For example, you can get the SF300-24P. I hope this information is helpful.
Brian Ng
04-04-2012 03:02 PM
So looking around at that line of switches it looks like the SG200-08P might be the right choice? It's Gigabit, has POE, it's Got the SG prefix as you mentioned. Isn't crazy expensive - it's a little more than the SD208P, but I just realized that wasn't even gigabit, this is what I get for trying to solve something in a hurry!
Chris.
04-04-2012 03:08 PM
Hi Chris,
The SG200-08P has mostly what you need and please make sure to upgrade to the latest firmware of 1.1.2.0 as that firmware will be able to power up your Cisco IP phone. I will also show you the link to download the latest firmware for the SG200 model devices listed below:
http://www.cisco.com/cisco/software/release.html?mdfid=283783779&flowid=24309&softwareid=282463182
I hope this helps.
Brian Ng
