Setting SNTP Time for SG500
reginachh
I had connected a computer and NTP to the SG500. i had successfullly sync the internet time on the computer. but when i type 'show clock' on the terminal. The switch did not manage to sync the ntp time.
below is my config, am i short of anything else?
clock timezone sg +8
clock source sntp
sntp unicast client enable
sntp server 192.168.4.36
Dan Miley
Level 3
Level 3
What is 192.168.4.36 ?
is that a workstation, a windows server, or linux box?
is NTP SERVER running on that box?
you could try pointing to one of these servers
https://support.ntp.org/bin/view/Servers/NTPPoolServers
sntp server pool.ntp.org
or point it to the same server your computer is pointing to.
Dan
** please flag posts that are helpful **
Hi Daniel,
The192.168.4.36  is a the NTP server which my computer is pointing to.
Could an ACL block the time from Synchronzing to the switch?
Gina
jonatrod
Level 7
Level 7
Good morning
Thanks for using our forum
Hi Regina, my name is Johnnatan and I am part of the Small business Support community. I´ve seen your post and I found some document that could help you.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2836
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2766
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
Cisco has a very useful tool called GuideMe, is made for small business products, and your device is in this category, you can use this address for accessing the tool:  http://sbkb.cisco.com/CiscoSB/Loginr.aspx?alt1=&pid=4&eroute=Super , is very easy to use, just complete the 3  spaces on this way:
Select a category: (Select the device type on request), e.g. Switch
Enter model: (Type the model on request), e.g. SG500
Question: (Type what  you want to know  about it), e.g. SNTP
And it'll be showing all the information you need about what you wrote.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
