Setting up for VOIP VLAN on SG 300
pnlam
I was told that I need to setup VLAN for my VOIP phone.  On my SonicWall firewall, I setup a separate VLAN 10 with it's own DHCP server.  I was told that on the SG300 each switch port that the phone is plugged in I need to set up to untag VLAN 10 and enable management.  What's the reason behind that?  Can someone explain?  Thanks in advance.
balaji.bandi
depends on requirement, as per the information most of the use case Phone connected with PC using same port
example reference :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb99-voice-vlan-configuration-on-the-200-300-series-managed-switc.html
BB
Adam Pawlowski
I am not clear on "enable management" and what that would mean in this context.
Many IP phones are designed to use a voice VLAN as a tagged VLAN after they hear an advertisement for one, or as configured by the administrator. They otherwise should just use whatever native/untagged network is present.
The SG300 has an auto voice VLAN mechanism that can trigger port configuration based on a few different things, including OUI. I typically try and have that turned off so that nothing unexpected happens if I am not planning to use it.
i take this as default VLAN 1 or any native vlan  "I am not clear on "enable management" and what that would mean in this context."
BB
