SF220: VLAN was not created by user
AlKor
Good day!
Before work with catalyst series and dont understand whats wrong.
Have SG350-10SFP as router, in port GI1 connected SF220-24.
At SF220 do:
QC-NOPOE#sh vlan
  VID  |     VLAN Name    |        Untagged Ports        |        Tagged Ports          |  Type
     1 |          default |           fa1-24,gi1-2,po1-8 |                          --- | Default
    10 |         VLAN0010 |                          --- |                          gi1 | Dynamic
    20 |         VLAN0020 |                          --- |                          gi1 | Dynamic
    30 |         VLAN0030 |                          --- |                          gi1 | Dynamic
    40 |         VLAN0040 |                          --- |                          gi1 | Dynamic
    50 |         VLAN0050 |                          --- |                          gi1 | Dynamic
    60 |         VLAN0060 |                          --- |                          gi1 | Dynamic
    70 |         VLAN0070 |                          --- |                          gi1 | Dynamic
    80 |         VLAN0080 |                          --- |                          gi1 | Dynamic
    90 |         VLAN0090 |                          --- |                          gi1 | Dynamic
   100 |         VLAN0100 |                          --- |                          gi1 | Dynamic
VLANs created at SG350.
Now try config FA18 interface in access mode with VLAN 10
QC-NOPOE#conf t
QC-NOPOE(config)#int fa18
QC-NOPOE(config-if)#switchport access vlan 10
This work with C2960:
interface GigabitEthernet3/0/35
 switchport mode access
 spanning-tree portfast
What i do wrong?
Configs attached
2 Accepted Solutions
Sujoy Paria
This is happening as GVRP is enabled on both the Switches, due to that VLANs created on the SG350 has been propagated to SF220 Switch and VLANs (10 to 100) are showing as ‘Dynamic’. On the Small Business Switches you will be not able to associate those dynamic VLANs on the Switch port, you need to specify /create those VLANs statically.
AlKor
Yes, found it byself (read old topic about sg 300)
I set at all SF200 :
gvrp enable
at uplink ports too
and manually create empty vlans
#conf t
#vlan 10
#ex
#vlan 20
#ex
and so on
after this ping and trace route work between switches and different VLANs.
Sujoy Paria
AlKor
gvrp enable
at uplink ports too
#conf t
#vlan 10
#ex
#vlan 20
#ex
and so on
Great ! Good to know that it is working now
