SF300-24P with Avaya phones
CSCO11068191
Greetings Everyone,
I am having a Cisco Small Business SF300-24P Switch and I'm trying to connect it to an avaya phones and it's giving me the headache of a lifetime for 3 days now. I've tried all sorts of switchports and Voice Vlan settings and LLDPs and everything. I think I've even messed up with the data vlan after it was working fine and I probably a weird configurations now would anyone please try to help me out with it.
Thanks a lot
Here are the configs:-
User Name:cisco
Password:***********
switch0a1172#
switch0a1172#
switch0a1172#
switch0a1172#
switch0a1172#sho run
config-file-header
switch0a1172
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 9,13,20
exit
voice vlan id 20
voice vlan state auto-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone___
voice vlan oui-table add 00036b Cisco_phone________
voice vlan oui-table add 00096e Avaya______________
voice vlan oui-table add 000fe2 H3C_Aolynk_________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_
voice vlan oui-table add 00d01e Pingtel_phone______
voice vlan oui-table add 00e075 Polycom/Veritel_pho
voice vlan oui-table add 00e0bb 3Com_phone_________
voice vlan oui-table add 3475c7 Avaya
lldp med network-policy 1 voice-signaling vlan 20 v
hostname switch0a1172
line telnet
password c8e383b1dd7be99f878a387d87766e875404e0b3 e
exit
username cisco password encrypted c8e383b1dd7be99f8
lege 15
ip telnet server
interface vlan 13
ip address 192.168.11.1 255.255.255.0
interface vlan 20
no ip address dhcp
interface fastethernet1
spanning-tree portfast
switchport mode access
switchport access vlan 13
lldp med enable
lldp management-address automatic
no macro auto smartport
interface fastethernet2
lldp med enable
interface fastethernet3
switchport mode general
switchport general allowed vlan add 13 untagged
lldp med enable
interface fastethernet4
lldp med enable
interface fastethernet5
lldp med enable
interface fastethernet6
lldp med enable
interface fastethernet7
lldp med enable
interface fastethernet8
spanning-tree link-type point-to-point
lldp med enable
macro description switch
!next command is internal.
macro auto smartport dynamic_type unknown
interface fastethernet9
lldp med enable
interface fastethernet10
lldp med enable
interface fastethernet11
lldp med enable
interface fastethernet12
lldp med enable
interface fastethernet13
lldp med enable
interface fastethernet14
lldp med enable
interface fastethernet15
lldp med enable
interface fastethernet16
lldp med enable
interface fastethernet17
lldp med enable
interface fastethernet18
lldp med enable
interface fastethernet19
lldp med enable
interface fastethernet20
lldp med enable
interface fastethernet21
lldp med enable
interface fastethernet22
lldp med enable
interface fastethernet23
lldp med enable
interface fastethernet24
lldp med enable
interface gigabitethernet4
switchport access vlan 9
macro auto disabled
switch0a1172#
Tom Watts
Hi Abdulrahman, the config seems kind of weird.
I'd just default the switch and follow this document-
https://supportforums.cisco.com/docs/DOC-27005
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
7 Replies 7
Tom Watts
-Tom
my dear friends thanks for the help
i restored it to factory settings and did as says in the link
but what about switchport ? what about assigning data and voice vlans
Abdul, all of this would be automatically done through the macro of the switch. There is not any additional configuration needed. If the phone is not working, I'd double check to see if CDP or LLDP is enabled.
-Tom
Bro how about if i have many data vlans how would i assign ports to vlans ??!!!
Depending how you'd like. Per example
vlan 1 = default
vlan 2 = data 1
vlan 3 = data 2
vlan 20 = voice
config t
int fa06
switchport trunk native vlan 2
-Tom
One thing was missing
Port to vlan selecting the voice vlan and selecting tagging on the ports
(also when we select the voice vlan we should click on "go" cause it's tricky it shows you the vlan you selected without actually selecting it unless u click on go)
other than that all what you mentioned helped a lot so thank a zillion bro
Hi, I could really do with reading this article, but it tells me I'm not authorized. is is published anywhere else? or is there an updated version??
