SF302-08 - CLI configuration of dhcp option 66
Luis Azedo
i'm trying to use cli to configure dhcp option 66 but i'm getting this error below.
thanks
switch702df6(config-dhcp)#ip dhcp pool network Voice
switch702df6(config-dhcp)#option 66 ascii-string "http://provisioning.domain.tld/$MA.xml"
% Wrong number of parameters or invalid range, size or characters entered
Tom Watts
Hi Luis, I do not believe option 66 is supported.
1, 3, 4, 6, 12, 15, 44, 46, 50, 51, 53, 54 55, 56, 58, 59, and 61.
If you remove the name of your file, you will notice the switch declares it is an unsupported option
switchb28f36(config-dhcp)#option 66 ascii test
Not supported option.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
