Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 968 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5722 Views
  • 1 replies
  • 16 Helpful votes
Hi All,Am  trying to do inter vlan routing using Cisco Switch SG200-50 with Cisco  Router 1941. On router I have created three subinterface for VLAN1,2,3  and VLAN1 is native vlan. I have a LWAP with Cisco WLC connected to same  switch. I have enable...
Joseph J by Level 1
  • 1286 Views
  • 1 replies
HiI am using SG300-10 and connected it to two SG200 with LACP and PoEWhen I tried to use ssh client to check poe status via cli, the switch suddenly rebooted.After this, the poe is dead.I reset the switch, reconfigured the settings but ..as soon as I...
leihuang by Level 1
  • 2422 Views
  • 6 replies
HelloI have SG300-20 working in Layer3 modeVLAN1 is not usedInternet gateway is in VLAN211Clients are in other VLANsSwitch is default gateway for clients and itself has internet gateway as default route.MAC address of switch is XX:XX:XX:XX:XX:63 When...
Hi,i'm trying to configure SF302-08P in layer 3 mode.ports 1 to 8 have ip phones and desktops, port GE1 in connected to a router (not cisco) that links to the internet.i created vlan 100 and assigned to ports 1 to 8 (untagged)i created vlan 200 and a...
Hello , We have some trouble with our cisco Small Businnes SF300.after an electricity failure the switch won't start again the system led is blinking but there is no link ont he fast/gigabit port and nothing can be done.This is the second one with th...
Hola a todos son nuevo en el tema y tengo el siguiente problema. Mi proveedor me entrego 5 IP publicas por fibra optica, estas llegan a un swtiche Huawei. Del swtiche Huawei va un cable a un servidor Isa Server y del Isa Server en otra tarjeta de red...
taxbelen1 by Level 1
  • 752 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
