SFP support Cisco 350 and 350X series MGBLX1
Does Cisco 350 series model SF350-24MP and SF352-08MP-K9 and
350X series model  SG350XG-24F support    SFP MGBLX1
it should work fine , it doesn't specify it in the doc but that SFP is part of same data sheet ,usually there always backward compatible the SFP+ ports
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/small-business-network-accessories/datasheet-c78-741408.html
Table 1. MGE SFP transceiver modules
Model
Description
MGBLH1
1000BASE-LH SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 40 km
MGBLX1
1000BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 10 km
MGBSX1
1000BASE-SX SFP transceiver for multimode fiber, 850 nm wavelength, supports up to 500 m
MGBT1
1000BASE-T SFP transceiver for Category 5 copper wire, supports up to 100 m
If you spec the one that works in sfop+ and the one that isn't listed , there near identical
https://www.cablerack.com/fiber-transceivers/cisco-compatible-transceivers/mgblx1.html
https://www.cablerack.com/mgblh1.html
Mark Malone
The guide says yes they are supported , page 12
FP ports are compatible with Cisco modules MGBT1, MGBSX1, MGBLH1, MGBLX1, MGBBX1, MFELX1, MFEFX1, and MFEBX1, as well as other brands of modules.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350_/2_3/quick_start/guide/en-US/Cisco350-QSG-en-US.pdf
Thank you Mark,
I asked question because I found this
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data-sheet-c78-737359.html
Supported SFP modules
SKU
Media
Speed
Maximum Distance
MGBSX1
Multimode fiber
1000 Mbps
350 m
MGBLH1
Single-mode fiber
1000 Mbps
40 km
MGBT1
UTP cat 5
1000 Mbps
100 m
and also for 350X
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xseries/2_4/admin_guide/english/AG_Tesla_350_550.pdf
page 29
The SFP+ ports are compatible with the following Cisco SFP 1G optical modules MGBSX1, MGBLH1, MGBT1, as well as other brands.
Can you confirm that SFP+ is compatibile with MGBLX1.
Model
Description
MGBLH1
MGBLX1
MGBSX1
MGBT1
