04-06-2023 07:58 AM
i have a 10g sfp and i am adding SN and give me answer that is 1000base
fns20431356
04-06-2023 10:20 AM
- Check the serial number here : https://cway.cisco.com/sncheck/
M.
04-07-2023 12:40 AM
yes i looked there. But it looks like a 1000base sfp. But mine is 10g so why bring me wrong product with this SN?
04-07-2023 03:34 AM
- Why do you think it is 10g ?
M.
04-08-2023 06:58 PM
Take a picture of the optic's serial number. Post it here.
04-08-2023 08:10 PM
@xariskk24 given serial of sfp is GLC-SX-MMD and its not 10G. check if your SFP SKU. for 10G SFPs, it is SFP-10G-SR
04-08-2023 11:40 PM
04-09-2023 12:39 AM
@xariskk24 its 10G. your typo done mistake in serial. normally warranty for SFPs are bound to the connected device as per my understanding. if this defective, you can open TAC case using device serial which this is connected to.
04-08-2023 11:34 PM
I am sure you need to check one of the digit wrongs in the provided number - fns20431356 ( that will change into different product).
if you sure its 10GB then check the numbers again
you can also insert to device - and you can see show inventory and show interface ten x/x trans
04-08-2023 11:41 PM
you can see the photo.
04-08-2023 11:42 PM
thank you all for your answers. I spoke with cisco chat agent and told me that otherwise is too old component and didnt have any warranty.
04-08-2023 11:55 PM
fns20431356 ( 5 = S)
You typed the SR Number wrong - change from 5 to S - it will show you correctly.
04-09-2023 02:09 AM
Yes, I did take a look. It appears to be a 1000base sfp, though. But why did you send me the incorrect product with this SN while mine is 10g?
04-09-2023 07:48 PM
SKU is SFP-10G-SR.
