SG 300-20 Link Issues
digitalchild
I've searched around and can't seem to find anyone else with this problem.
I've got an sg 300-20 installed in my network that is showing quite a few errors with links dropping on both the data and voice vlans.
The ram log is littered with these:
2147482407           2011-Jul-06 09:07:32          Informational           %LINK-I-Up: g8
2147482408           2011-Jul-06 09:07:26          Warning           %LINK-W-Down: g8
2147482409           2011-Jul-06 09:07:00          Informational           %LINK-I-Up: g8
2147482410           2011-Jul-06 09:06:58          Warning           %LINK-W-Down: g8
2147482411           2011-Jul-05 23:03:14          Informational           %LINK-I-Up: g11
2147482412           2011-Jul-05 23:03:12          Warning           %LINK-W-Down: g11
G8 has a PC plugged into it and g11 has an SPA 504g cicso phone plugged into it.
The ports change (this is just a sample)
Network setup is the following:
UC320 => SG300-20
PC's on even ports
Phones on odd ports.
uc320 running phones and data vlans and DHCP server.
VLANS:
vlan 1 (data) untagged on all ports on sg 300
vlan 100 (voice) tagged on ports that have the phones plugged in.
Port 1 of uc320 => G20 on sg 300-20 for uplink.
G20 is also tagged with voice vlan.
STP is off. (I've tried it with and without this turned on without any difference).
Green Ethernet is off.
QoS is at defaults.
Everything else is default.
I can't seem to work out where in the network this would occur. Any help or direct would be greatly appreciated.
6 Replies 6
apex_tech
Same thing here, first switch was in place for about 1 year, then it started doing this, disabled STP (had some small switches in place). That only stopped it for about 1 day, came back with several messages, always picks on the same ports. Called and got a replacement switch, the reason why: If you notice if you do manual time set on the switch not NTP it will reset it to the factory time for the firmware! So new switch came in, everything was fine for about 2 weeks - then BAM! Started happening again, going down today to see if I can remove the last of the non cdp enabled switches, and install a small 8 port SG. Using smartport, will define as switch, no vlans are in use. Will set each port manually and see if that resolves it.
Would like to know what the deal is myself, application in use there is extremely network intensive perhaps its pushing the switch too far and this site needs a catalyst series to handle... Would hate to have to eat it, but will do to make the client happy!
Same problem here, I have three SG300-52 ports, and link are droping all the time. Is it possible that no one from Cisco did not reply to this or give some advice how to fix this problem.
Bellow log:
    2147483447   2013-Feb-05 19:30:20 Notice   %SYSLOG-N-NEWSYSLOGSERVER: configure new syslog server 192.168.1.9
    2147483449   2013-Feb-05 19:28:28 Informational   %AAA-I-CONNECT: New http connection for user fortuna, source 192.168.1.113 destination 192.168.1.251 ACCEPTED
    2147483455   2013-Feb-05 17:57:18 Informational   %AAA-I-DISCONNECT: http connection for user fortuna, source 192.168.1.3 destination 192.168.1.251 TERMINATED
    2147483456   2013-Feb-05 17:56:19 Warning   %STP-W-PORTSTATUS: gi11: STP status Forwarding
    2147483457   2013-Feb-05 17:56:14 Informational   %LINK-I-Up:  gi11
    2147483458   2013-Feb-05 17:56:12 Warning   %LINK-W-Down:  gi11
    2147483460   2013-Feb-05 17:45:29 Warning   %STP-W-PORTSTATUS: gi36: STP status Forwarding
    2147483461   2013-Feb-05 17:45:25 Informational   %LINK-I-Up:  gi36
    2147483462   2013-Feb-05 17:45:22 Warning   %LINK-W-Down:  gi36
    2147483463   2013-Feb-05 17:39:22 Warning   %STP-W-PORTSTATUS: gi26: STP status Forwarding
    2147483464   2013-Feb-05 17:39:17 Informational   %LINK-I-Up:  gi26, aggregated (1)
    2147483465   2013-Feb-05 17:39:16 Warning   %LINK-W-Down:  gi26, aggregated (1)
    2147483466   2013-Feb-05 17:39:12 Informational   %LINK-I-Up:  gi26
    2147483467   2013-Feb-05 17:39:11 Warning   %LINK-W-Down:  gi26
    2147483468   2013-Feb-05 17:31:04 Informational   %AAA-I-DISCONNECT: http connection for user fortuna, source 192.168.1.82 destination 192.168.1.251 TERMINATED
    2147483470   2013-Feb-05 17:25:49 Warning   %STP-W-PORTSTATUS: gi43: STP status Forwarding
    2147483471   2013-Feb-05 17:25:44 Informational   %LINK-I-Up:  gi43
    2147483472   2013-Feb-05 17:25:44 Warning   %STP-W-PORTSTATUS: gi23: STP status Forwarding
    2147483473   2013-Feb-05 17:25:41 Warning   %LINK-W-Down:  gi43
    2147483474   2013-Feb-05 17:25:40 Informational   %LINK-I-Up:  gi23
    2147483475   2013-Feb-05 17:25:38 Warning   %LINK-W-Down:  gi23
    2147483476   2013-Feb-05 17:25:36 Warning   %STP-W-PORTSTATUS: gi48: STP status Forwarding
    2147483477   2013-Feb-05 17:25:31 Informational   %LINK-I-Up:  gi48
    2147483478   2013-Feb-05 17:25:29 Warning   %LINK-W-Down:  gi48
    2147483479   2013-Feb-05 17:19:25 Warning   %STP-W-PORTSTATUS: gi40: STP status Forwarding, aggregated (1)
    2147483480   2013-Feb-05 17:19:20 Informational   %LINK-I-Up:  gi40, aggregated (1)
    2147483481   2013-Feb-05 17:19:18 Warning   %LINK-W-Down:  gi40, aggregated (1)
    2147483482   2013-Feb-05 17:15:36 Warning   %STP-W-PORTSTATUS: gi40: STP status Forwarding
    2147483483   2013-Feb-05 17:15:36 Warning   %STP-W-PORTSTATUS: gi36: STP status Forwarding
    2147483484   2013-Feb-05 17:15:32 Informational   %LINK-I-Up:  gi40
    2147483485   2013-Feb-05 17:15:31 Informational   %LINK-I-Up:  gi36
    2147483486   2013-Feb-05 17:15:28 Warning   %LINK-W-Down:  gi36
    2147483487   2013-Feb-05 17:15:14 Warning   %LINK-W-Down:  gi40
    2147483488   2013-Feb-05 17:14:29 Informational   %INIT-I-Startup: Warm Startup
    2147483489   2013-Feb-05 17:13:59 Informational   %AAA-I-CONNECT: New http connection for user fortuna, source 192.168.1.82 destination 192.168.1.251 ACCEPTED
    2147483490   2013-Feb-05 17:13:35 Informational   %AAA-I-CONNECT: New http connection for user fortuna, source 192.168.1.3 destination 192.168.1.251 ACCEPTED
    2147483492   2013-Feb-05 17:13:09 Notice   %SYSLOG-N-LOGGING: Logging started.
    2147483493   2013-Feb-05 17:12:51 Warning   %STP-W-PORTSTATUS: gi9: STP status Forwarding
    2147483494   2013-Feb-05 17:12:46 Informational   %LINK-I-Up:  gi9
    2147483495   2013-Feb-05 17:12:43 Warning   %STP-W-PORTSTATUS: gi26: STP status Forwarding
    2147483496   2013-Feb-05 17:12:41 Warning   %STP-W-PORTSTATUS: gi10: STP status Forwarding
    2147483497   2013-Feb-05 17:12:40 Warning   %STP-W-PORTSTATUS: gi6: STP status Forwarding
    2147483498   2013-Feb-05 17:12:40 Warning   %STP-W-PORTSTATUS: gi37: STP status Forwarding
    2147483499   2013-Feb-05 17:12:39 Warning   %STP-W-PORTSTATUS: gi30: STP status Forwarding
    2147483501   2011-Nov-13 00:33:38 Informational   %LINK-I-Up:  gi26
    2147483502   2011-Nov-13 00:33:38 Warning   %STP-W-PORTSTATUS: gi42: STP status Forwarding
    2147483503   2011-Nov-13 00:33:37 Informational   %LINK-I-Up:  gi10
    2147483504   2011-Nov-13 00:33:36 Informational   %LINK-I-Up:  gi6
    2147483505   2011-Nov-13 00:33:36 Informational   %LINK-I-Up:  gi37
    2147483506   2011-Nov-13 00:33:35 Informational   %LINK-I-Up:  gi30
Thanks in advance
Darko
Hi Darko, can you give more details about what is connecting to the switch? A small diagram would be fantastic.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
from your log entries it looks like your switch is rebooting itself
If you can I would disable STP, all the green ethernet stuff, bonjour, CDP, and anything else that is not absolutely required. See if it stabilizes the switch, it did for us. I updated ours to the most recent firmware version version as well. I had to disable STP on it even after it was replaced because of the occasional reboot. Our environment was a flat small network, no VOIP, just a couple of switches and to main switches (one located in each building) connected by fiber between. The funny thing about all this - they had some old dell switches that were not manageable. I talked them into spending the extra money to get manageable switches (VOIP and other services in the near future) from Cisco, only to have to disable all the extras...lol...
Oh and to complicate matters, it would send out malformed CDP packets when it rebooted... they also had a Cisco SA520... yes... it would reboot upon receiving malformed cdp packets. So we had to disable CDP on the SA520. Ya... it was a rough month but everything is quiet now.
Thank you all for fast reply. I want to clarify that this was not happen before 05.02.2013,  suddenly it start with all switches… Very strange thing is that the ports between switches were never down also all was fine with the ports where the servers are. Tried whole day to find some rule, also track everything with syslog server. I will give you log files and excel files with cumulative ports down on all switches…
I appreciate all your effort and help.
Darko
abccisco2011
Did anyone found a solution to this? I am also having the same problem. I disabled STP and it was fine for 2 days after that the problem came back again?
Thanks for your help in advance.
Sushant
