sg200-08: 802.1x unauthorized access / MAC-auth
dieter.pichler
I use 802.1x to authenticate the company-network devices - authentication works fine.
I do not use dynamic VLANS --> static VLAN-config on 802.1x ports --> authenticated devices have access to the network.
Is ist possible to use a guest-VLAN? unauthenticatet devices shoud connect to an other vlan than authenticated devices.
One more question: Is MAC-authentication also possible?
Switch: SLM2008T V01
Firmware is: 1.0.1.0
Regards Dieter
Glenn Quesenberry
Dieter,
     For those features (Guest VLAN & MAC ACL) you would need to look at one of the Cisco 300 Series Small Business Switches, those two features are not available on the 200 line.
Best Regards,
