03-31-2014 01:48 PM
Hello
Given SG200-50 don't have CLI, how can I create VLAN but make sure they're able to connect together?
I have a Cisco router already connected to the switch. Is is necessary for the VLAN to talk to each other? Can the switch do that on its own? Do I need another router to do it?
Thanks! :)
Solved! Go to Solution.
03-31-2014 05:27 PM
Hi Dan, the SG200 switch is a layer 2 device. This means if you'd like the VLAN to communicate to one another a router or layer 3 device would have to do this for you. By nature, VLANS do not talk to each other. A routing device must accomplish that for you.
04-02-2014 02:00 PM
Dan, this will work if your router supports 802.1q sub interface or if it supports trunk and VLAN tag.
03-31-2014 05:27 PM
04-01-2014 06:37 AM
Thank you for your reply. The fact that the switch is already connected to a router should do the trick then?
04-02-2014 02:00 PM
04-02-2014 02:11 PM
I understand. Thank you. Thanks to your post I discovered that my router is indeed not what I need for multiple VLANs.
https://supportforums.cisco.com/discussion/11863656/help-vlanssubnets-rv042g
I will have to buy another router.
