SG200-50P fan noise problem
delikomat
Hello, i need help to solve problem with fan control. Sometimes, once per day, the switch start to run fan at full speed. I understood it can be when temperature increase. But running this full speed all the time, only power off helps. Thank you, Marek Ján
Brandon Svec
Level 7
Level 7
Are you running latest firmware 1.3.7.18 and boot 1.3.5.06?
-- please remember to rate and mark answered helpful posts --
Brandon Svec
Level 7
Level 7
Thanks Brnadon, i have fw 1.3.1 so i will upgrade to the latest version and we will see. Regards, Marek Ján
Hi, you answer was correct. Now i see Events about fan speed change so it was easy to troubleshoot temperature problem. Thank you, Marek Ján
dkislits
Hello everyone!
Made all updates, but it's still noisy.
Anyone knows fan model-size? Want to replace it with quiet version
Thanks!
Dmitry
