10-31-2016 03:42 PM
I have many sg200's that I'm configuring through dhcp auto config. It works great but I'm having problems finding documentation on commands allowed to be used in the config file. I am trying to find a command that will write the running-config to the startup-config. I'm not sure if it's even possible. The catalyst uses wr. The 200e uses write memory. Both wouldn't work for me but I could have the location wrong in my config file also. Can anyone help?
Solved! Go to Solution.
11-01-2016 11:40 AM
As far as I know, the Sx200 (as opposed to the 200e) doesn't support CLI, and as such doesn't have support for some of the functionality of the other models.
11-01-2016 11:40 AM
