SG220-50P 50-Port Gigabit PoE Smart Switch's PoE Status is OFF
keithliew
Anyone have any idea why the PoE Status showed OFF for all ports for my switch SG220-50P 50-Port Gigabit PoE Smart Switch?
AccSW3#show power inline
Power management mode: Class limit mode
Legacy device supports: enabled
Unit Power Status Nominal Allocated Consumed Available Usage Traps
Power Power Power Power Threshold
1 Off Normal 375Watts 0Watts (0%) 0Watts 375Watts 98 disabled
Port State Status Priority Class Max.Power Alloc.Power Device
(mW) (mW)
gi1 Auto off low class0 15400 0 N/A
gi2 Auto off low class0 15400 0 N/A
gi3 Auto off low class0 15400 0 N/A
gi4 Auto off low class0 15400 0 N/A
gi5 Auto off low class0 15400 0 N/A
gi6 Auto off low class0 15400 0 N/A
gi7 Auto off low class0 15400 0 N/A
gi8 Auto off low class0 15400 0 N/A
gi9 Auto off low class0 15400 0 N/A
gi10 Auto off low class0 15400 0 N/A
gi11 Auto off low class0 15400 0 N/A
gi12 Auto off low class0 15400 0 N/A
gi13 Auto off low class0 15400 0 N/A
gi14 Auto off low class0 15400 0 N/A
gi15 Auto off low class0 15400 0 N/A
--More--
marce1000
                      Check and or enable POE according to :
            STEP 1 Click Port Management > PoE > Port Settings.
            STEP 2 To edit the power limit per port, select a port and click Edit.
            STEP 3 Enter the following information:
               • Interface—Select the port to be configured.
               • PoE Administrative Status—Enable or disable PoE on the port.
 M.
balaji.bandi
is any device connected to that ports ?
BB
keithliew
Connected Avaya IP phone to port 20, it works.
Connect the same IP Phone to other port, it didn't work.
Called Cisco support and they arrange RMA for our unit cos the same issue happened even updated to latest firmware.
post complete output of show power inline when the phone connected to port 20
BB
