SG250 signed firmware
tato386
Level 6
Level 6
Starting with v2.5.7 the firmware files have "signed" in the name.  What is the upgrade path if I am currently on v2.4.0?  Can I go straight to a signed firmware?  Is there some prep step I need to take before apply a signed firmware?
it doesnt matter. you can upgrade to 2.5.X lower version first and then go to required version.
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-550x-series-stackable-managed-switches/smb5304-upgrade-firmware-on-a-switch.html?referring_site=RE&pos=4&page=https://www.cisco.com/c/en/us/support/switches/sg250-26-26-port-gigabit-switch...
Good luck
KB
FYI:  I first applied the highest non-signed 2.5.x firmware, after that I applied the latest signed image and switch is good.  I am sure you are correct and I could have gone straight to signed version but I figured a pit stop on the way to signed imaged couldn't hurt.
Thank you!
