SG250 Voice and Data Traffic Conf issue.
irfanjamil1994
I have SG250 24P POE, i am configuring both voice and Data traffic in an interface but after switch reboot the interface conf. automatically changed.
Voice: VLAN 162
Data: VLAN 199
conf t
int giX
switchport mode trunk
switch port allowed vlan 162,199
switchport trunk native vlan 199
but after switch reboot native VLAN automatically omit from configuration. I need to configure both voice and data vlan in same port.
Plz suggest me how to configure the port or if i am doing wrong so kindly correct me.
Thanks & Regards,
IRFAN
Hope i have suggested same topic, do you have any duplicated post ?
Try below : and check .
no macro description ip_phone_desktop
no macro auto smartport dynamic_type ip_phone_desktop
BB
5 Replies 5
balaji.bandi
what is the config after reload? what firmware?
BB
Hi Balaji,
Please guide me how to allow both Data & Voice VLAN in a port.
Voice: VLAN 162
Data: VLAN 199
Below are the conf. I did for Data & Voice VLAN.
interface GigabitEthernet5
storm-control broadcast level 10
storm-control multicast level 10
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
!next command is internal.
But after switch reboot it reset the conf. as per below.
switchport trunk allowed vlan 1,162
Firmware Info.
XXXXXX#sh version
Active-image: flash://system/images/image1.bin
Version: 2.5.0.83
MD5 Digest: 07968d912499cff5e8b07fdc24779854
Date: 18-Jun-2019
Time: 16:49:35
Inactive-image: flash://system/images/_image1.bin
Version: 2.5.0.83
Date: 18-Jun-2019
Time: 16:49:35
Waiting for your response.
BB
Hi Bajali,
Issue has been resolved now.
Thanks for your kind support.
Martin Aleksandrov
@irfanjamil1994
First off, try to disable smart ports on the switch. Syntax of the command is switchport trunk allowed vlan {all | none | add vlan-list | remove vlan-list | except vlan-list} so basically has to issue switchport trunk allowed vlan add {VLANs list}
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/cli_guide/CLI_Tesla_SG350X_SG350XG_2_2_5.pdf
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4986-vlan-configuration-via-cli-on-300-500-series-managed-switche.html
