SG250X and SX250X GVRP Config
rCaliputoc16
Hi Guys,
I have SX350X as my core switch and SG250X for access switch. SX350X is configured as a stack with a port channel configured with a trunk. This is also a same setup on my SG250X. I'm currently working for a GVRP configuration as the port channel and also two ports were configured with GVRP enable only which is also the same on my SG250X. How do I able to propagate the VLANS to SG250X. Thank you in advance
balaji.bandi
Make sure you have latest Firmware installed and supported.
you need to enable Globally first before interface. as described in the document as below :
here is the steps  using CLI :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5830-configure-gvrp-settings-on-a-switch-through-the-cli.html
here is the steps  using GUI :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-250-series-smart-switches/smb2754-configure-gvrp-settings-on-a-switch.html
BB
Hi Sir,
Thanks for the response. I've already configured GVRP globally and also enable this per port which is also configured as trunk and port channel. I've also tried to add vlan-creation and registration but still no avail. This were also configured on both switches. I've also configured it in GUI but still it's not working. I've also added switchport trunk vlan allowed but still wont work.
Version: 2.5.0.83 as per show version
Can you share the configuration and output as mentioned document for us to review.
BB
