SG300-10 Ethernet connected, but no IP-connectivity
insaf
I have a strange problem with a SG300-10 (our first SG300) working as a desktop switch.
When a PC that is connected to the switch is powered off and is later (a few minutes or next day) switched on, the PC has a ethernet-connection to the switch, but no IP-connectivity.
The PC-statistics shows that ethernet is connected and it sends packets, but the PC does not receive any packets.
At the same time the SG300 statistics for the port says, that the ethernet is connected (same paramaters as the PC) an that the switch is sending IP-packets (broadcast and unicast) to the port, but does not receive any packets. The switch shows follwing entries in the ram log for the port:
09:11:35Warning    %STP-W-PORTSTATUS: gi3: STP status Forwarding, aggregated (1)
09:11:31Informational    %LINK-I-Up:  gi3, aggregated (1)
09:11:28Warning    %LINK-W-Down:  gi3
09:11:24Warning    %STP-W-PORTSTATUS: gi3: STP status Forwarding
09:11:19       Informational    %LINK-I-Up:  gi3
With the older firmware 1.2.9.44 the IP-connectivity worked after waiting 5-10 minutes.
With the new firmware 1.3.0.59 I can wait even 15 minutes, there is no change and nothing happens.
But when I change some "unimportant" parameters of the port (i.e. change port speed from autonegation to fixed 1000M, or vice versa) and then save the running configuration to the startup-config, around 5-10 Seconds after the configuration is saved, the port gets full IP connectivity and after that works fine (until the PC is switched OFF and ON the next time).
This is a very strange behaviour. As "PC" I have tested this with HP-workstations, Lenovo Thinkpad and a MAC Mini. The switch "reacts" to all the same.
Following I have attached the config of the switch.
It would be very appreciated if someone could give me some hints on how to solve or debug this issue further.
Thanks very much
Andreas
config-file-header
sw3
v1.3.0.59 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator plaintext
no cdp log mismatch native
no cdp log mismatch voip
no cdp appliance-tlv enable
port jumbo-frame
vlan database
vlan 2,4-5,10
exit
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
green-ethernet short-reach
no bonjour enable
hostname sw3
line console
no autobaud
exit
line console
speed 19200
exit
logging buffered debugging
no passwords complexity enable
username cisco password encrypted xxxxxxxxxxxx 7 privilege 15
ip ssh server
snmp-server server
clock timezone " " 1
clock summer-time web recurring eu
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 192.168.112.7
ip domain name abc.de
ip name-server  192.168.112.7
interface vlan 1
no ip address dhcp
interface vlan 2
name 2
interface vlan 4
name 4
interface vlan 5
name 5
ip address 192.168.112.15 255.255.255.0
ipv6 address 2001:abc:100b:25::15/64
interface vlan 10
name 10
interface gigabitethernet1
switchport mode access
switchport access vlan 5
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
no eee enable
negotiation 1000f
no eee lldp enable
no green-ethernet energy-detect
interface gigabitethernet8
no mdix
interface gigabitethernet9
no eee enable
negotiation 100h 100f 1000f
no eee lldp enable
interface gigabitethernet10
no eee enable
no mdix
switchport mode general
switchport general allowed vlan add 2,4-5,10 tagged
switchport general ingress-filtering disable
switchport general pvid 5
no eee lldp enable
switchport default-vlan tagged
exit
macro auto disabled
ip route 0.0.0.0 /0 192.168.112.1 metric 1
Tom Watts
Hi Andreas, this is not usual. I would assume if you factory reset the switch it will work just fine.
I have 4 of these running right now on my desktop and none them behave like this.
It should take 2-5 minutes for fully connectivity after a boot up. And not more than 52 seconds (depending on spanning tree) for new connection without boot up.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Hi Tom,
thanks for your reply,
it took me some time, but after a factory reset and a complete new configuration, which looks exactly like the old config in the text-editor, the switch now works without this problem.
So, could this problem happen again, if we upgrade to a newer firmware in the future?
In a production environment, we can not "reset to factory default" after we do a firmware upgrade, just "to make sure" nothing strange happens after the upgrade.
Andreas
Hi Andreas, in a product environment you do not generally upgrade firmwares. If something works there is "no need to fix it" kind of mentality.
I work for a large ISP and more often than not a lot of our software images may be considered ancient even, for the simple fact there is no need to upgrade software. But at the same time we have a very comprehensive "approved software list" as well.
The one thing I've learned working for one of the top 10 largest ISP in the US is that every vendor with any software has potentially adverse affects simply because old coding does not support new features and the such. And sadly, when we transition from lets say an old ATM code to a new ETHERNET code, more often than not, we usually have to rebuild a lot of configurations from scratch. It seems to be just a fact of life.
The only problem I know for sure is that... the small business team doesn't like people using old software and generally you won't get support until you're on the most recent releases, but it is also with good reason as those newer releases usually fix a lot of old bugs - but - the downfall is the fact that it may have adverse impacts on configuration items.
-Tom
