Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3501 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5173 Views
  • 1 replies
  • 16 Helpful votes
Hi All, I am trying to use SFP module from one transceiver to the cisco switch . I have a general sfp device which the lighs turn on when plugged in from port 28 to 27 which are sharfed sfp but do not work if port 28 is connected to another fiber tra...
Random44F by Level 1
  • 1134 Views
  • 1 replies
Greeting's, I have a SG-300-28P Switch running firmware - 1.3.0.62. Switch is in L2 mode with 24 nodes forwarding traffic to a firewall. I want to log ALL traffic on the switch to a syslog server. I already have a syslog server logging traffic from a...
I would like to use my SG300-20 to have 2 VLANs share a single network printer.  What would be the best practice for this situation.  Right now the switch is set in L3 mode.  I do have flexibility right now for it is not in use and willing to start a...
Please Help have a Question ..The MGBSX1  is compatible with SG500X model ?? , because SG500X say uplinks   4*10 Gigabit Ethernet SFP+ (2*10 GE+ 2*10GE/5GE-Stacking Combo)the MGBSX1 is 1000mb/1GB ,   also work , or not , only 10g SFP support .Kind re...
                  I am getting follwoing eror logs and port is in errordisable mode. What may be the reasonJun 28 18:00:36.516: %ILPOWER-5-ILPOWER_POWEROVERDRAWN: Interface Gi9/2 is shutdown as  it is consuming more power (8234) than the configured m...
Hi,I have an SRW248G that every so often just hangs and a reboot fixes it.  In the logs I get the following error message after the reboot:%SYSLOG-F-OSFATAL: HOST_go: Not enough free memory for OS *****FATAL ERROR***** Reporting tast: ROOT. Software ...
Hi,I just upgrade to 1.3.0.62 on an SG300-52 (from 1.2.7.76). This renders the switch completely unusable:the switch seems to continue to operate as configured butthe web interface is not reachable at allwhen logged in through ssh everything seems no...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
