SG300-10 IPv4 Routes Bug
schoep851
Hello together
I bought the SG300-10 Switch a few days ago and updated it to firmware 1.3.0.59, but i think there's a bug in this firmware.
If I go to "IP Configuration" IPv4 Routes" in L3 Mode nothing is displayed. In the log file i see that:
21474773112013-Mar-16 09:51:34Error%HTTP_HTTPS-E-DIAGNOSTICS: ERROR - in <RL_vtLeadTableGet> tag, can not find the table rlInetRoutingDistanceTable in the MIB.
21474775182013-Mar-14 22:39:22Error%HTTP_HTTPS-E-DIAGNOSTICS: ERROR - in <RL_vtLeadTableGet> tag, can not find the table rlInetRoutingDistanceTable in the MIB., aggregated (1)
Reset of the Switch doesn't help.
Anyone have the same problem?
Thanks for help.
Hi Ephraim, this is a known bug and should be resolved in the upcoming maintenance release 1.3.0.62. I cannot give an ETA for the release of this software. However, if this is a pressing issue, please contact the small business support center requesting an escalation to the tier 2 team and asking for the firmware.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
Hi Ephraim, there shouldn't be routes unless you make a SVI and have an active connection or you make static routes.
-Tom
Hello Tom
I have 4 VLAN's and can also add a static route, but nothing appears in the Web-GUI.
With the CLI command "show ip route" i see the routes.
Thanks.
Seems you're right. Interesting. I'll chip away at this and see what I can find.
-Tom
-Tom
