06-02-2017 04:53 AM
Can anyone confirm is MFEFX1 (100BASE-FX) the correct SFP compatible with SG300-10SFP small business switch, to support 100Mb MM fibre 1310 nm wavelength, support up to 2 km?
The MFEFX1 quick start guide document does not list this switch as compatible only the SG300-10, SG300-10P and SG300-10MP devices are listed?
thanks in advance
06-02-2017 04:43 PM
Please find in the SG300 Series Data Sheet the supported Transceivers..
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Glenn
01-31-2018 12:22 PM
Hello, can you confirm if you ever tried this? I find the referenced document not specific enough for my liking (I am used to Catalyst switches where you cannot use 100Mbps SFPs in a GX/X/X SFP slot). Thank you
06-05-2018 01:48 AM
