SG300-10SFP transceiver compatibility
curtis03_2
Can anyone confirm is MFEFX1 (100BASE-FX) the correct SFP compatible with SG300-10SFP small business switch, to support 100Mb MM fibre 1310 nm wavelength, support up to 2 km?
The MFEFX1 quick start guide document does not list this switch as compatible only the SG300-10, SG300-10P and SG300-10MP devices are listed?
thanks in advance
Glenn Martin
Please find in the SG300 Series Data Sheet the supported Transceivers..
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Glenn
Mikel Ward
Hello, can you confirm if you ever tried this? I find the referenced document not specific enough for my liking (I am used to Catalyst switches where you cannot use 100Mbps SFPs in a GX/X/X SFP slot). Thank you
smailmilak
Level 4
Level 4
here it says that it's supported.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
"SFP ports are compatible with Cisco modules MGBT1, MGBSX1,
MGBLH1, MGBLX1, MGBBX1, MFELX1, MFEFX1, and MFEBX1, as well as
other brands of modules"
