SG300-20 Truncated Config Output
mountainet
I've inherited a dozen or so SG300-20 switches without knowing the current passwords.  Therefore, I have used the system reset button to restore one of the switches to the factory defaults.  So far, so good.  However, when I try to display the running-config, it appears as if it's being truncated as follows:
switcha96ef8>
Detected speed: 115200
switcha96ef8>en
switcha96ef8#show running-config
config-file-header
switcha96ef8
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switcha96ef8
switcha96ef8#
I am using the following PuTTY serial connection settings: 115200,8,1,None,XON/XOFF
Even if I change the configuration of one of the ports, it doesn't show in the output.
Has anyone else ever experienced this and/or have a recommendation of how to fix it?
Thanks!
6 Replies 6
mipopov
You have very old firmware (2014 year), please, upgrade to latest and reset to factory again. Link to the newest firmware version:
https://software.cisco.com/download/home/283019616/type/282463181/release/1.4.9.4?i=!pp
 Cheers,
Mike
Thanks Mike!  I will do just that.
-Mark
Deepak Kumar
In the old version of Firmware I noticed that if your port is down than it will not show port configuration on gui and cli.
Try to make port up and second best advise to upgrade it.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks Deepak!  Even with the firmware upgrade, an interface will not show up in the configuration if it is shutdown.
-Mark
CORRECTION:  When displaying the configuration using the CLI, an interface will display regardless of status as long as it is configured.
If your switch port is not configured and showing configuration as
sho run interface FastEthernet7
Empty configuration
It will not reflect in running and startup configuration.
Deepak Kumar
Deepak Kumar,
