SG300-28 in L3 no InterVlan routing?
viningele
Level 3
Level 3
      I have an SG300-28 and I'm not able to ping from VLAN interface's IP to clients in other vlans.  It's got to be something simple I'm missing but I'm not seeing it and I've run out of things to try.
I have 3 vlans 1, 11 & 25 and I'm connected via a trunk to an RV320.  All vlans access the internet no problem but I can't access vlan 11 from 1 or 1 from vlan 11.  25 is guest wi-fi and shouldn't access the others and doesn't.
SW-SG300-28-1#show run
config-file-header
SW-SG300-28-1
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
no spanning-tree
vlan database
vlan 11,25
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
no eee enable
ip dhcp server
ip dhcp pool network GUEST-POOL
address low 192.168.176.50 high 192.168.176.199 255.255.255.0
lease 0 2
default-router 192.168.176.10
dns-server 8.8.8.8 8.8.4.4 192.168.175.1
exit
ip dhcp pool network POS_POOL
address low 192.168.11.100 high 192.168.11.120 255.255.255.0
default-router 192.168.11.10
dns-server 8.8.8.8
exit
no boot host auto-config
bonjour interface range vlan 1
ip access-list extended DENY-GUESTS-IN
deny ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
deny ip 192.168.176.0 0.0.0.255 192.168.177.0 0.0.0.255
exit
ip access-list extended Allow-non-Guests
deny ip 192.168.176.0 0.0.0.255 any
permit ip any any
exit
ip access-list extended "ALLOW ALL"
permit ip any any
exit
hostname SW-SG300-28-1
line console
exec-timeout 30
exit
line ssh
exec-timeout 30
exit
line telnet
exec-timeout 30
exit
no passwords complexity enable
passwords aging 0
ip ssh server
snmp-server server
ip http timeout-policy 1800
clock timezone " " -5
clock summer-time web recurring usa
clock source sntp
clock source browser
ip name-server  8.8.8.8 8.8.4.4 192.168.175.1
ip host cameras 192.168.175.144
ip telnet server
interface vlan 1
ip address 192.168.175.148 255.255.255.0
no ip address dhcp
service-acl input Allow-non-Guests default-action permit-any
interface vlan 11
name POS_
ip address 192.168.11.10 255.255.255.0
interface vlan 25
name "Guest Wi-Fi"
ip address 192.168.176.10 255.255.255.0
interface gigabitethernet1
ip arp inspection trust
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
switchport mode access
switchport forbidden vlan add 25
macro description desktop
macro auto smartport type desktop $max_hosts 10 $native_vlan 1
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
switchport access vlan 11
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
description PAK_AP_Bar
spanning-tree link-type point-to-point
service-acl input DENY-GUESTS-IN default-action permit-any
switchport trunk allowed vlan add 11,25
macro description ap
macro auto smartport type ap
interface gigabitethernet24
description PAK_AP_Kit
interface gigabitethernet25
description Router
service-acl input "ALLOW ALL" default-action permit-any
macro description router
macro auto smartport type router $native_vlan 1
interface gigabitethernet26
macro description switch
macro auto smartport type switch $native_vlan 1
interface gigabitethernet27
interface gigabitethernet28
exit
ip default-gateway 192.168.175.1
SW-SG300-28-1#
[KSW-SG300-28-1#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S   0.0.0.0/0 [1/1] via 192.168.175.1, 00:13:29, vlan 1
C   192.168.11.0/24 is directly connected, vlan 11
C   192.168.175.0/24 is directly connected, vlan 1
C   192.168.176.0/24 is directly connected, vlan 25
SW-SG300-28-1#show vlan
Created by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN
Vlan       Name                   Ports               Created by
1           1             gi1-8,gi23-28,Po1-8            D
11        POS_                  gi9-28                   S
25     Guest Wi-Fi              gi23-28                  S
SW-SG300-28-1#
9 Replies 9
Tom Watts
Hi Vini, on the RV320, do you have intervlan capability enable or disable for vlan 11 and 11?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
It's disabled on all vlans in the rv320 since I'm expecting the switch to handle intervlan routing.
Additionally the RV320 is the dhcp server for vlan 1 on x.x.x.1 and the dhcp server is disabled for vlans 11 & 25.  The switch has dhcp server enabled and pools for vlans 11 & 25.  No ip routes int the RV either for vlans interfaces on switch.
Hi Vini, I was about to ask the same then I saw the email notice. I see only 1 DHCP pool excluding the guest (since we don't need to talk about guest).
dns-server 8.8.8.8
So you should enable intervlan routing on the RV320 OR you need to let the switch give DHCP for VLAN 1 and handle the VLAN 1 routing. Right now you're using VLAN 1 in a layer 2 capacity since the gateway is not the switch - it's the router.
-Tom
Ok, turning off the dhcp server for vlan 1 in the RV320 and adding a pool in the switch is simple enough and I had wanted to that on this system anyway but never got around to it.  I didn't think this would affect routing on the switch since I did create a ip interface for vlan 1 on it and it comes up as a direct route in show ip route so I tried just about everything else.  I have noticed some odd behavior when enabling vlan routing on the RV320 sort of like a loop that I attributed to routing in both locations but that's just me guessing.
In the RV320 > DHCP Setup should I just disable the server or use DHCP Relay and input the ip of the vlan interface/dhcp server in the switch.  Does it matter?
Hi Vinni, personally I'd just use the switch. It's a stronger/more robust product than any of the SB routers.
-Tom
Yeah that's what I did and it was easiy enough to do remotely with out losing remote access.  The whole point of using this switch in L3 mode was so I could handle the routing internal to the switch and not have to go out to the router and back to the switch at wire speed to accomplish the routing.
From what I've read the RV320 DHCP server should be disabled not DHCP relay for my needs since the DHCP servers on the switch are on the same VLANs.
I was worried about the PPTP VPN DHCP server on the RV after disabling DHCP for VLAN 1 (default) but it still seems to work fine and must operate independent and I just added that range of IPs to the excluded DHCP table on the switch so I should be good there.
So for future reference to achieve intervlan routing I not only need to create a vlan interface IP but also need to create a DHCP pool even if I don't need a DHCP server because creation of the pool activates the DHCP server and the routing function?
Hi Vini, the DHCP server isn't relevant to achieve intervlan routing. The DHCP server would only play a role in assigning the correct default gateway to a host.
-Tom
