Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3631 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5316 Views
  • 1 replies
  • 16 Helpful votes
Hi,I need to buy an entry level switch with the following features:qos configurationsecurity features like port security, ACLs, NAC, IBNSlayer 3 featuresetmay or may not be modularat least 24 portsat least 6 POE portsPlease suggest the low cost model...
Scenario: I would like to be able to have a static block of ports and a dhcp block of ports on the same SG300 switch.ISP - Business Cable Cable Modem supplied by ISP has 1 Wan Port.I have:Static block of 8 usable IP addressesConnected directly to thi...
mattb by Level 1
  • 618 Views
  • 1 replies
Hi,I have an SG300-28P and I need to upgrade both the boot & firrmware versions.The problem is I can't find the boot file anywhere, the only file available on the Cisco downloads page is the firmware file ('.ros')These are my current versions:show ve...
idh by Level 1
  • 3414 Views
  • 2 replies
We have had an interesting situation occur at least twice on a stack of SGE2010 switches. It appears that port 80 on certain devices attached to teh switch will respond to paping on port 80, but will not allow access to the web page information. If t...
On the SG300 & 500 I always seem to have issue with devices that have reserved IPs.  It seems if I enter its MAC in the reservations table for some devices it won't receive the assigned IP until I remove the MAC and use a Client ID instead but on...
viningele by Level 3
  • 515 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
